Reply 20 of 47, by Baldy-Aussie
This whole "Problem" seems a tad ridiculous to my way of thinking. Sort of "When I project an old 8 mm film onto a 32 foot HiMax screen, it is too faint! Wah! Wah!" COME ON NOW! Most of those old DOS games were designed for, & played on 12 or 14 inch monitors, while sitting 10 or 12 inches away from them. Trying to fill a 4k screen with a 640 x 480 VGA set of information just isn't going to be pretty. (307.2 kb of information spread over 8,294.4 kb of screen? Pixels are going to be 27 times the original area.) My own solution is to use a nice big Hi-Def screen for Movies, and an old 21 inch Phillips for DOS Gaming. Doesn't make any sense to me to take the 30 tonne truck to pick up a bottle of soft-drink!
Reply 21 of 47, by Azarien
With modern resolutions so high, it is not unreasonable to have normal4x, 5x, 6x etc. scalers in addition to current 2x and 3x.
The whole point of DOSBox is to make old games work on modern systems. If you can play on original hardware the way those games were intended to be played - good, but keep in mind that old hardware is getting harder and harder to find.
Reply 22 of 47, by Ant_222
I disagree. First, you should compare linear sizes rather than areas (megapixels make no sense perception-wise). Second—the entire 4K resolution cannot be used because of the wider aspect ratio of monitor. The limiting factor therefore is the vertical resolution:
2160 / 480 = 4.5 .
Third—T\the dpi of your 4K monitor is likely higher than of the historical models from the MS-DOS era. Fourth—modern monitors are viewed comfortably from a longer distance, which further decreases the difference.
The simplest and most important requirement for the faithful reproduction of an old game is to display it at the same or similar angular size, indifferently of the actual resolution of one's monitor. The second requirement is to avoid any pixel-level distortions by general-purpose algorithms, such as interpolation, and preserve a crystal-crisp image through the application of integer scale factors, as my pixel-perfect patch does for any output resolution. The third, and hardest, requirement is to emulate the artefacts of a CRT display. This latter should be optional, to satisfy pixel purists, and highly customizable, for the solutions are rather non-trivial.
Reply 23 of 47, by dugan
I am shocked that no-one's asked to see SpectrVR's conf settings, or asked him which platform platform he's using (it sounds like Windows, but don't assume that unless you hear it).
His issue sounds to me like his DosBox is using outout=surface, either explicitly or as a fallback.
Reply 24 of 47, by Ant_222
dugan, yes the hay smelleth of that weed, but I must say that the other output modes of the standard DOXBox are equally "unusable" at high resolutions because they introduce distortion by interpolation and are unable to keep the image a) crisp, b) with regular pixels (unlike nearest-neighbor), and c) with more or less correct aspect ratio, e.g. upscaling 320x200 game to a scale of 5 horizontally and 6 vertically so as to come up with a sharp 1600 x 1000 image.
Reply 26 of 47, by Ant_222
It may be a bug in the pixel-perfect patch. Does it work in windowed mode? Does fullscreen work with surface output? Have specified fullscreen resolution as desktop?
Reply 27 of 47, by SGAN
- It works in windowed mode.
- Full screen doesn't work with surface output
- I had specified fullscreen resolution as "original"
Gonna try as "desktop"
EDIT:
It crashes with this config:
fullscreen=true
fulldouble=true
fullresolution=desktop
windowresolution=original
output=surface
autolock=true
sensitivity=100
waitonerror=true
priority=higher,normal
mapperfile=mapper-0.74.map
titlebar=DOSBox ECE Test
usescancodes=true
Reply 28 of 47, by Ant_222
Then it seems unconnected with pixel-perfect. AFAIK., ECE comes in two versions: plain vanilla and enhanced. Can you try the plain vanilla version? Edit: also, please, try the same without fulldouble.
Reply 31 of 47, by Ant_222
SGAN, please, reproduce the crash with the attached build of DOSBox and send me the file debug.txt that it will create in the working directory. Make sure to test with
output=surface
By default, this version uses the following config file:
%userprofile%\Local Settings\Application Data\DOSBox\dosbox-SVN.conf
Also, please, attach the your full config file.
    DB_Debug.zip
    1.23 MiB
    77 downloads
Reply 32 of 47, by Ant_222
SGAN, I cannot correct the error you reported without your cooperation. Whereas it is not present in my environment, I am forced to take the long and tedious way of remote dubugging, wherein you are to test several modified builds and send logs back to me.
Reply 33 of 47, by SGAN
EDIT: I downloaded the 4052 version, and now it works perfectly with those config files
I'm sorry, I have not much time 'cause of my job.
I've been testing it, and it must be a problem of my config file or my "windows", cause it happens with the DOSBox-X releases too.
But no problems with the base/unmodified DosBox version
# This is the configurationfile for DOSBox 0.74. (Please use the latest version of DOSBox)
# Lines starting with a # are commentlines and are ignored by DOSBox.
# They are used to (briefly) document the effect of each option.
[sdl]
# fullscreen: Start dosbox directly in fullscreen. (Press ALT-Enter to go back)
# fulldouble: Use double buffering in fullscreen. It can reduce screen flickering, but it can also result in a slow DOSBox.
# fullresolution: What resolution to use for fullscreen: original or fixed size (e.g. 1024x768).
# Using your monitor's native resolution with aspect=true might give the best results.
# If you end up with small window on a large screen, try an output different from surface.
# windowresolution: Scale the window to this size IF the output device supports hardware scaling.
# (output=surface does not!)
# output: What video system to use for output.
# Possible values: surface, overlay, opengl, openglnb, ddraw.
# autolock: Mouse will automatically lock, if you click on the screen. (Press CTRL-F10 to unlock)
# sensitivity: Mouse sensitivity.
# waitonerror: Wait before closing the console if dosbox has an error.
# priority: Priority levels for dosbox. Second entry behind the comma is for when dosbox is not focused/minimized.
# pause is only valid for the second entry.
# Possible values: lowest, lower, normal, higher, highest, pause.
# mapperfile: File used to load/save the key/event mappings from. Resetmapper only works with the defaul value.
# usescancodes: Avoid usage of symkeys, might not work on all operating systems.
fullscreen=true
fulldouble=true
fullresolution=original
output=surface
autolock=true
sensitivity=100
waitonerror=true
titlebar=X-Men - Children of the Atom
usescancodes=true
[dosbox]
# language: Select another language file.
# machine: The type of machine tries to emulate.
# Possible values: hercules, cga, tandy, pcjr, ega, vgaonly, svga_s3, svga_et3000, svga_et4000, svga_paradise, vesa_nolfb, vesa_oldvbe.
# captures: Directory where things like wave, midi, screenshot get captured.
# memsize: Amount of memory DOSBox has in megabytes.
# This value is best left at its default to avoid problems with some games,
# though few games might require a higher value.
# There is generally no speed advantage when raising this value.
language=
machine=svga_s3
captures=capture
memsize=30
[render]
# frameskip: How many frames DOSBox skips before drawing one.
# aspect: Do aspect correction, if your output method doesn't support scaling this can slow things down!.
# scaler: Scaler used to enlarge/enhance low resolution modes.
# If 'forced' is appended, then the scaler will be used even if the result might not be desired.
# Possible values: none, normal2x, normal3x, advmame2x, advmame3x, advinterp2x, advinterp3x, hq2x, hq3x, 2xsai, super2xsai, supereagle, tv2x, tv3x, rgb2x, rgb3x, scan2x, scan3x.
frameskip=0
aspect=false
Show last 189 lines
scaler=normal
[cpu]
# core: CPU Core used in emulation. auto will switch to dynamic if available and appropriate.
# Possible values: auto, dynamic, normal, simple.
# cputype: CPU Type used in emulation. auto is the fastest choice.
# Possible values: auto, 386, 386_slow, 486_slow, pentium_slow, 386_prefetch.
# cycles: Amount of instructions DOSBox tries to emulate each millisecond.
# Setting this value too high results in sound dropouts and lags.
# Cycles can be set in 3 ways:
# 'auto' tries to guess what a game needs.
# It usually works, but can fail for certain games.
# 'fixed #number' will set a fixed amount of cycles. This is what you usually need if 'auto' fails.
# (Example: fixed 4000).
# 'max' will allocate as much cycles as your computer is able to handle.
# Possible values: auto, fixed, max.
# cycleup: Amount of cycles to decrease/increase with keycombo.(CTRL-F11/CTRL-F12)
# cycledown: Setting it lower than 100 will be a percentage.
core=auto
cputype=auto
cycles=auto
cycleup=10
cycledown=20
[mixer]
# nosound: Enable silent mode, sound is still emulated though.
# rate: Mixer sample rate, setting any device's rate higher than this will probably lower their sound quality.
# Possible values: 44100, 48000, 32000, 22050, 16000, 11025, 8000, 49716.
# blocksize: Mixer block size, larger blocks might help sound stuttering but sound will also be more lagged.
# Possible values: 1024, 2048, 4096, 8192, 512, 256.
# prebuffer: How many milliseconds of data to keep on top of the blocksize.
nosound=false
rate=44100
blocksize=1024
prebuffer=20
[midi]
# mpu401: Type of MPU-401 to emulate.
# Possible values: intelligent, uart, none.
# mididevice: Device that will receive the MIDI data from MPU-401.
# Possible values: default, win32, alsa, oss, coreaudio, coremidi, none.
# midiconfig: Special configuration options for the device driver. This is usually the id of the device you want to use.
# See the README/Manual for more details.
mpu401=intelligent
mididevice=default
midiconfig=
[sblaster]
# sbtype: Type of Soundblaster to emulate. gb is Gameblaster.
# Possible values: sb1, sb2, sbpro1, sbpro2, sb16, gb, none.
# sbbase: The IO address of the soundblaster.
# Possible values: 220, 240, 260, 280, 2a0, 2c0, 2e0, 300.
# irq: The IRQ number of the soundblaster.
# Possible values: 7, 5, 3, 9, 10, 11, 12.
# dma: The DMA number of the soundblaster.
# Possible values: 1, 5, 0, 3, 6, 7.
# hdma: The High DMA number of the soundblaster.
# sbmixer: Allow the soundblaster mixer to modify the DOSBox mixer.
# oplmode: Type of OPL emulation. On 'auto' the mode is determined by sblaster type. All OPL modes are Adlib-compatible, except for 'cms'.
# Possible values: auto, cms, opl2, dualopl2, opl3, none.
# oplemu: Provider for the OPL emulation. compat might provide better quality (see oplrate as well).
# Possible values: default, compat, fast.
# oplrate: Sample rate of OPL music emulation. Use 49716 for highest quality (set the mixer rate accordingly).
# Possible values: 44100, 49716, 48000, 32000, 22050, 16000, 11025, 8000.
sbtype=sb16
sbbase=220
irq=7
dma=1
hdma=5
sbmixer=true
oplmode=auto
oplemu=default
oplrate=44100
[gus]
# gus: Enable the Gravis Ultrasound emulation.
# gusrate: Sample rate of Ultrasound emulation.
# gusbase: The IO base address of the Gravis Ultrasound.
# Possible values: 240, 220, 260, 280, 2a0, 2c0, 2e0, 300.
# gusirq: The IRQ number of the Gravis Ultrasound.
# Possible values: 5, 3, 7, 9, 10, 11, 12.
# gusdma: The DMA channel of the Gravis Ultrasound.
# Possible values: 3, 0, 1, 5, 6, 7.
# ultradir: Path to Ultrasound directory. In this directory
# there should be a MIDI directory that contains
# the patch files for GUS playback. Patch sets used
# with Timidity should work fine.
gus=false
gusrate=44100
gusbase=240
gusirq=5
gusdma=3
ultradir=C:\ULTRASND
[speaker]
# pcspeaker: Enable PC-Speaker emulation.
# pcrate: Sample rate of the PC-Speaker sound generation.
# tandy: Enable Tandy Sound System emulation. For 'auto', emulation is present only if machine is set to 'tandy'.
# Possible values: auto, on, off.
# tandyrate: Sample rate of the Tandy 3-Voice generation.
# disney: Enable Disney Sound Source emulation. (Covox Voice Master and Speech Thing compatible).
pcspeaker=true
pcrate=44100
tandy=auto
tandyrate=44100
disney=true
[joystick]
# joysticktype: Type of joystick to emulate: auto (default), none,
# 2axis (supports two joysticks),
# 4axis (supports one joystick, first joystick used),
# 4axis_2 (supports one joystick, second joystick used),
# fcs (Thrustmaster), ch (CH Flightstick).
# none disables joystick emulation.
# auto chooses emulation depending on real joystick(s).
# (Remember to reset dosbox's mapperfile if you saved it earlier)
# Possible values: auto, 2axis, 4axis, 4axis_2, fcs, ch, none.
# timed: enable timed intervals for axis. Experiment with this option, if your joystick drifts (away).
# autofire: continuously fires as long as you keep the button pressed.
# swap34: swap the 3rd and the 4th axis. can be useful for certain joysticks.
# buttonwrap: enable button wrapping at the number of emulated buttons.
joysticktype=auto
timed=true
autofire=false
swap34=false
buttonwrap=false
[serial]
# serial1: set type of device connected to com port.
# Can be disabled, dummy, modem, nullmodem, directserial.
# Additional parameters must be in the same line in the form of
# parameter:value. Parameter for all types is irq (optional).
# for directserial: realport (required), rxdelay (optional).
# (realport:COM1 realport:ttyS0).
# for modem: listenport (optional).
# for nullmodem: server, rxdelay, txdelay, telnet, usedtr,
# transparent, port, inhsocket (all optional).
# Example: serial1=modem listenport:5000
# Possible values: dummy, disabled, modem, nullmodem, directserial.
# serial2: see serial1
# serial3: see serial1
# serial4: see serial1
serial1=dummy
serial2=dummy
serial3=disabled
serial4=disabled
[dos]
# xms: Enable XMS support.
# ems: Enable EMS support.
# umb: Enable UMB support.
# keyboardlayout: Language code of the keyboard layout (or none).
xms=true
ems=true
umb=true
keyboardlayout=auto
[ipx]
# ipx: Enable ipx over UDP/IP emulation.
ipx=false
[autoexec]
# Lines in this section will be run at startup.
# You can put your MOUNT lines here.
imgmount d "XMEN_PC.cue" -t iso
MOUNT C .
C:
CD X-Men
XMENPC.exe
exit
I tried using "ascpect=true" and X-Men Children of the Atom shows itself bad (corrupted image)... I finally had to use "fullresolution=original" and "aspect=false" with the "unmodified DOSBox version
EDIT: This config files worked fine too:
DDraw HQ2x
[sdl]
fullscreen=true
fulldouble=true
output=ddraw
autolock=true
sensitivity=100
waitonerror=true
usescancodes=true
[dosbox]
language=
machine=svga_s3
captures=capture
memsize=30
[render]
frameskip=0
aspect=false
scaler=hq2x
[cpu]
Show last 186 lines
core=auto
cputype=auto
cycles=auto
cycleup=10
cycledown=20
[mixer]
nosound=false
rate=44100
blocksize=1024
prebuffer=20
[midi]
mpu401=intelligent
mididevice=default
midiconfig=
[sblaster]
sbtype=sb16
sbbase=220
irq=7
dma=1
hdma=5
sbmixer=true
oplmode=auto
oplemu=default
oplrate=44100
[gus]
gus=false
gusrate=44100
gusbase=240
gusirq=5
gusdma=3
[speaker]
pcspeaker=true
pcrate=44100
tandy=auto
tandyrate=44100
disney=true
[joystick]
joysticktype=auto
timed=true
autofire=false
swap34=false
buttonwrap=false
[serial]
serial1=dummy
serial2=dummy
serial3=disabled
serial4=disabled
[dos]
xms=true
ems=true
umb=true
keyboardlayout=auto
[ipx]
ipx=false
[autoexec]
MOUNT C .
C:
CD X-Men
XMENPC.exe
exit
DDraw Super2xSai:
[sdl]
fullscreen=true
fulldouble=true
output=ddraw
autolock=true
sensitivity=100
waitonerror=true
usescancodes=true
[dosbox]
language=
machine=svga_s3
captures=capture
memsize=30
[render]
frameskip=0
aspect=false
scaler=super2xsai
[cpu]
Show last 186 lines
core=auto
cputype=auto
cycles=auto
cycleup=10
cycledown=20
[mixer]
nosound=false
rate=44100
blocksize=1024
prebuffer=20
[midi]
mpu401=intelligent
mididevice=default
midiconfig=
[sblaster]
sbtype=sb16
sbbase=220
irq=7
dma=1
hdma=5
sbmixer=true
oplmode=auto
oplemu=default
oplrate=44100
[gus]
gus=false
gusrate=44100
gusbase=240
gusirq=5
gusdma=3
[speaker]
pcspeaker=true
pcrate=44100
tandy=auto
tandyrate=44100
disney=true
[joystick]
joysticktype=auto
timed=true
autofire=false
swap34=false
buttonwrap=false
[serial]
serial1=dummy
serial2=dummy
serial3=disabled
serial4=disabled
[dos]
xms=true
ems=true
umb=true
keyboardlayout=auto
[ipx]
ipx=false
[autoexec]
MOUNT C .
C:
CD X-Men
XMENPC.exe
exit
OpenGL Normal scaler:
[sdl]
fullscreen=true
fulldouble=true
output=opengl
autolock=true
sensitivity=100
waitonerror=true
titlebar=titlebar=X-Men - Children of the Atom
usescancodes=true
[dosbox]
language=
machine=svga_s3
captures=capture
memsize=30
[render]
frameskip=0
aspect=false
scaler=normal
[cpu]
Show last 186 lines
core=auto
cputype=auto
cycles=auto
cycleup=10
cycledown=20
[mixer]
nosound=false
rate=44100
blocksize=1024
prebuffer=20
[midi]
mpu401=intelligent
mididevice=default
midiconfig=
[sblaster]
sbtype=sb16
sbbase=220
irq=7
dma=1
hdma=5
sbmixer=true
oplmode=auto
oplemu=default
oplrate=44100
[gus]
gus=false
gusrate=44100
gusbase=240
gusirq=5
gusdma=3
[speaker]
pcspeaker=true
pcrate=44100
tandy=auto
tandyrate=44100
disney=true
[joystick]
joysticktype=auto
timed=true
autofire=false
swap34=false
buttonwrap=false
[serial]
serial1=dummy
serial2=dummy
serial3=disabled
serial4=disabled
[dos]
xms=true
ems=true
umb=true
keyboardlayout=auto
[ipx]
ipx=false
[autoexec]
MOUNT C .
C:
CD X-Men
XMENPC.exe
exit
Reply 38 of 47, by krondalix
Hi ! For thoses who are using 4K Monitors i have found great solution.
Most of you just need this trick for it to work:
Right click on dosbox.exe file, see compatibility panel then replace the DPI for use by "Software" that should do the trick. The fact is because in 4K resolution your windows basical fonts has to be 200 or 250% if you want to be able to read 😜
For thoses who have further graphical problem:
First here are my configs for this to work (using SVN-Daum 2015 version):
[render]
frameskip=0
aspect=false <-- you might change this to true if you want real 4:3 in fullscreen mode. Note that in windowed maximized it's better to disable this option
linewise=false
char9=false
doublescan=false
scaler=hardware2x <-- you can put any you want there. Don't forget to force scaler if you're using D3D pixelshaders and opengl output methods. I took a love for the tv2x or rgb2x using CRT shaders 😀
autofit=false
[sdl]
fullscreen=false
fulldouble=false
windowresolution=desktop
output=direct3d <-- you can of course use any of other ones. they all works but note that direct3d is the only one that has this "maximize window" working. All others switch directly in fullscreen mode. And i notified and for all others you need too to force scalers for they to work properly and apparently that does not work in DirectDraw mode.
autolock=true
sensitivity=100
waitonerror=true
mapperfile=mapper-SVN-Daum.map
pixelshader=none
usescancodes=true
overscan=0
If you experience Flickering using d3d pixelshaders, it's because of colors vibrance regarding scanlines (you can either configure that within your built-in screen settings) or by the nvidia colors settings.
You have to tweak in nvidia the saturation slider either less than 30% or more than 70% for flicker to disappear.
You can also change your color temp to hotter or colder.
This flicker problem generally occurs in CGA games.
Glad that helps you.
