First post, by kanecvr
Hi guys. I'm trying to get a K6-2+ to run on my PA-2013 to no avail. The board posts, and the CPU is ID'd as a K6 at 66MHz??? but it refuses to boot. It hangs just after counting memory. I updated the BIOS to the latest version found on the FIC FTP site, but it still won't ID the CPU correctly or boot.
Here's the BIOS I used:
Ji1537.rar
109.55 KiB
18 downloads
Could someone with bios modding please have a look and tell me if it supports the K6-2+? Thanks!
Reply 1 of 3, by kanecvr
[SOLVED]
Ok I figured it out. Only the ji4333 beta bios supports "+" CPUs. It also supports large hard drives. It's kind of hard to find so I'll post a copy of it here:
FIC PA-2013 2.0 K6-2+ / K6-3+ and large HDD JI4333 beta bios:
ji4333.rar
124.54 KiB
53 downloads
Reply 2 of 3, by gdjacobs
Your first starting point for K6-2+ / K6-III+ should be Jan Steunebrink's page.
http://web.inter.nl.net/hcc/J.Steunebrink/k6plus.htm
Yes, he has the beta BIOS linked.
Reply 3 of 3, by kanecvr
Thanks for the link - saved for future reference. The bios I posted above works fine with the K6-2+ - unfortunately the boards's L2 cache is bad - luckily the K6-2+ has 128kb of L2 on die 😁
