identify 486 motherboard
Reply 40 of 49, by kalohimal
mpe wrote on 2020-06-22, 14:57:
Luckily I used bike seats to enhance my sex life. 😁 Ok shall use th99 next time now that I have run out of bike seats.
Slow down your CPU with CPUSPD for DOS retro gaming.
Reply 41 of 49, by jack7277
@mkarcher , thank you, you scare me a little, I did connect keyboard (usb -> usb-ps/2 -> ps/2-din5) and it works fine with no errors.
Reply 42 of 49, by mkarcher
Sorry to scare you. I can't remember having seen the "keyboard locked" message due to a missing keyboard, but if it works fine now, good for you. I will keep that in mind before scaring other people.
This actually looks fine, but oviously the BIOS is a bit dated and does not know the brand name of the DX4 processor. The generic "DX4-S" printout is normal on older Award BIOS editions with enhanced AMD 486 processors like the AMD 486DX4 and the AMD 5x86. It should not disturb normal operation. As far as I can remember, you get "DX4 100" printed with both the DX4 at 100MHz and the 5x86 at 133MHz. The BIOS always assumes 33MHz * 3 and does auto-config according to 33MHz front side bus clock. I think you will also get "DX4-S @ 100MHz" if you run at 3*40, 3*50MHz or 4*40MHz, so in that case, "auto config" in the chipset setup will tune the chipset to speeds that are known to work well at 33MHz, but might be unreliable at 40MHz. Main takeaway: Don't use auto-config if your bus clock is higher than 33MHz and your processor is faster than 100MHz. Manual config works fine without problems, and most people here on VOGONs are using manual config anyway to push their benchmark scores to the limit.
Reply 44 of 49, by Deksor
I am currently adding this board to Ultimate Hardware 2019 : http://www.win3x.org/uh19/motherboard/show/6235
However I'm gonna need some help with the jumpers and some other details like max supported ram, etc.
Here's the schema I have drawn so far in SVG :
Unknown PCI486 V1-HJ2.zip
32.99 KiB
56 downloads
65.05 KiB
PNG exported
I have respected the motherboard layout. Now I need to place jumpers and the chipset ...
Feel free to share any details or even improve this schema if you think something is wrong or can be improved.
Reply 45 of 49, by fiandro
Hello,
The other day I got this very same board (PCI486 V1-HJ3) with a DX266 on board. When powered up, nothing happens. The ISA diagnostic board reports no post codes, which is a bad sign usually. The PSU is ok because it works with my 386 board. I suspect it may be a hardware issue, but nothing obvious shows up (no cut traces on the back, no shorted pins), except perhaps C42 and C53 that a re a bit swollen. Any suggestion about how to revive this board, please ?
Thanks in advance!
Reply 46 of 49, by evasive
Start with checking if any of the power lines are shorted. Swollen capacitors are always bad news, be it shorted or open circuit.
Reply 47 of 49, by AngryByDefault
Tiido wrote on 2019-11-01, 00:48:
The cache ones are all traced out too and there's essentially 3 links to connect upper address lines of the 2 banks together or directly to some pins on the chipset. I don't yet know the significance of it, but the wrong BIOS definitely recognizes that there's 256KB of cache but will crash. I'll be tracing out how the cache is connected soon. It'll be a great board once there's working cache ~
quicknick wrote:
Hi, congrats on your work! I will be able to provide this next week if you're still interested. I'm out of the country at the moment.
I have actually figured out the way the jumpers work meanwhile so there's actual need to know them anymore with the exception of seeing the actual listed voltages, since I didn't actually measure exactly 3.3V or 3.45 etc. but more in all cases.
Hi!
So, I just happen to have gotten one of these boards and I wonder if the jumpers settings @Tiido posted at some point have been confirmed of corrected.
The reason I'm asking is this:
- The board runs slow and higly unstable, locking up frequently even when I am barely testing it. (FWIW it looks fine and was very clean)
- The sale was advertised as including a Cyrix 486, but the BIOS and utilities I've ran all detect it as an Intel 486 DX4 100. Perhaps the seller swapped the CPU when he agreed to lower the price and my jumpers are now wrong (I' d swear there was a pic with the BIOS showing "Cyrix" that was removed from the ad, but I was looking at so much stuff that I might be wrong...)
- Lastly, the jumpers came in a layout that does not match what Tiido found back when he worked on his board.
Tiido's findings:
10.13 KiB
My board:
The grey blocks show jumpers not matching Tiido's scheme for Intel, Cyrix nor AMD CPUs (but closer to Intel's)
9.83 KiB
Thanks in advance.
AbD
Reply 48 of 49, by Tiido
The lowest grey one essentially disables writeback funciton, making a cache flush every time a write happens as it connects Invalidate pin of an Intel/AMD CPU to read/write strobe. For Cyrix the middle pin is SUSPA which the right connection is toward right, where it is pulled up and suspend is disabled that way.
This jumper can make performance very slow, like on some motherboards in writeback mode except there's no dirty bit so they are flushing all the time and bringing performace down.
The second line from below is two jumpers, 123 and 45. 123 handle SMI and HITM pins, for Cyrix in needs to be 12 for mobo SMI to connect to CPU SMI, for Intel/AMD it needs to be 23 for the two to connect.
45 and the neigbhors right below are for L1 WB/WT control. Lower for WT, higher for WT.
I am confident the settings I traced out are correct, unless there are revisions of the board that do change meaning of the jumpers.
1.63 MiB
Reply 49 of 49, by AngryByDefault
Tiido, thank you for your feedback, I was hoping you would get notified of the post.
Yes, I actually trust your findings more that what was layed out on the board, so I figured I should ask a bit before I damage something here 😀
I will go by your comments and see if I can get it to work properly.
Will post back if there's anything useful I can share about it.
Regards!
