First post, by Gamecollector
Well, I try to replay this 20-years old classic. With 100% secrets of course.
Can't find 2 hidden rooms.
Middle Age part 2 - 3 rooms. 1) the start screen, the upper-left corner, to the left, 2) the Sorceress & undead knight screen, right wall. Can't find the last hidden area.
Conquistadors part 1 - 4 rooms. 1) the stern cabin, 2) the mizzen-mast top, 3) the hull, right from the up-ladder. Again, can't find the 4th hidded room.
Help anyone?
    Time Commando saves.7z
    191.5 KiB
    20 downloads
    Savegames (player 2, very easy, levels 1-5)
Reply 1 of 10, by Gamecollector
Up.
Reply 2 of 10, by Gamecollector
Up.
Reply 3 of 10, by L Lawliet
In the first room at Middle Age 2, jump in front of the table at right-upper corner to the arch where you can find a life.
edit: I found the last hidden room at Conquistadors today! You can see the boat right-upper corner where two sailors with guns appear. You can jump to the boat and find a life and red cubes.
Reply 4 of 10, by Gamecollector
Big tnx.
Reply 6 of 10, by Gamecollector
Some secrets are not hidden. As the example - the grenade box on the 2nd floor in the stable.
So - grab all items.
There are 17 secret items on this level (5.88% per item) and 4 secret rooms (25% per room).
There are 1 hidden place before the 2nd save (and this secret will be destroyed after you blow up the bunker). And 9 hidden places (with 13 items) after the 2nd save point. So - 3 secrets are "not hidden".
61.24 KiB
56.2 KiB
56.32 KiB
41.64 KiB
The secret in the 1st floor of the stable - 3 chips. So it adds 17%.
Reply 7 of 10, by Gamecollector
41.33 KiB
And yes, the secret is the grenade box, not the battery. I have tested.
63.53 KiB
The 1st secret is in the upper-right corner from the life. The red circle is wrong. Sorry.
The 2nd one - wheels.
52.65 KiB
3 chips, 17%.
44.22 KiB
Reply 8 of 10, by L Lawliet
Thanks, I only missed the hidden one right of the destroyed carriage. And to make sure, after the bunker is destroyed you can still have the hidden grenades.
It took nearly 20 years I finally play with 100& hidden rooms and bonuses!
Reply 9 of 10, by Gamecollector
100% of chips in Modern Wars 1? My record is 97%.
