Reply 20 of 24, by Guest
Ok, I set up a DOS 6.22 machine, and installed BARIS. This time it did pull up the modem-dial option, and it even dialed out...so maybe the issue is something Windows-related--like the way the game accesses the modem doesn't jibe with DOSBox or something.
And h-a-l is right; it's formatted for US 10-digit phone numbers only, which is one digit shy of a full IP address.
Reply 21 of 24, by Peyre
Here's a screenshot.
    71.94 KiB
Reply 22 of 24, by DosFreak
Are the "-" necessary? Do these count as extra characters? (I'm sure you already tried this).
Hmmm, might have to setup a VPN for this game to use smaller IP addresses.....or I wonder if dosbox could be coded to offer the option of tacking on an extra digit to the phone number for this game?
DOSBox Compilation Guides
DosBox Feature Request Thread
PC Game Compatibility List
Running DRM games offline
Reply 23 of 24, by HunterZ
Another idea would be to have a section in the config file in which the user can define virtual phone numbers and corresponding IP addresses that they should map to.
