Deyellowing Plastic
First post, by Oldskoolmaniac
Ok so the case on my Dell Optiplex GS+ is in bad shape its very yellow im going to see how close to white I can get it.
Cause of yellowing:
Most plastic was mixed with bromine a flame retardant chemical, the chemical would rise to the surface when expose to high amounts of uv light.
The fix:
A strong amount of hydrogen peroxide and uv light to activate the bromine, let sit for few hours and rinse and repeat if still yellow.
Tools used:
Philips screw driver (to pull all the guts out of case)
40 Volume salon hair creme (developer kind)
Black light
    1.77 MiB
    1.38 MiB
    1.48 MiB
    964.69 KiB
    1.51 MiB
Motherboard Reviews The Motherboard Thread
Plastic parts looking nasty and yellow try this Deyellowing Plastic
Reply 3 of 22, by Oldskoolmaniac
Yea ill get some after pic's, but its turning out really good.
I should also add, keep the room a little dark with just a black light hovered over top of the plastic and also wear gloves when applying the creme this stuff burns.
Reply 4 of 22, by brostenen
Oldskoolmaniac wrote:
this stuff burns.
I bet, that it would just rip all infection out of a wound, like it was max ripping the head off that crazy doctor. 🤣
Reply 5 of 22, by oeuvre
I cleaned up a GX110 a few months ago. used comet + hand soap and an old toothbrush. Afterwards, used fine sandpaper for scratches. Came out pretty nice but not perfect. http://imgur.com/a/8yaFC
Reply 8 of 22, by Oldskoolmaniac
r.cade wrote:
Black light doesn't work, or if at all, incredibly slowly. All you are doing is bleaching it with that concentration.
It will work with good sunlight, or possibly heat only.
yea the black light is a little slower, but it works good my case is now bleach white. I use the black light cause it winter and overcast.
Reply 10 of 22, by Oldskoolmaniac
......And here are the final results. It turned out really well, very clean white Case.
    1.6 MiB
    1.74 MiB
Reply 11 of 22, by foey
Great Job! Very interesting.
So what is the future state post this? i.e. will the yellowing come back again?
Cyrix Instead Build, 6x86 166+ | 32mb SD | 4mb S3 Virge DX | Creative AWE64 | Win95
ATC-S PIII Tualatin Win9x Build :- ATC-S PIII Coppermine Win9x Build Log [WIP] **Photo Heavy**
Reply 12 of 22, by Oldskoolmaniac
I will post in the future if it comes back, but I'm also going keep it out of direct sun light.
Reply 14 of 22, by TheMobRules
Errius wrote:
Has anyone tried this "retr0bright" stuff?
From what I've heard, what really matters in the de-yellowing process is the peroxide + UV light combination. retr0bright adds something called OxyClean on top of it, but I don't think it makes much of a difference.
The important thing is to be able to apply the peroxide in a way that it sticks and doesn't evaporate easily, that's why a creme-like substance such as that hair salon stuff is used instead of regular liquid peroxide.
If you're putting your case under direct sunlight, some people also recommend to cover it with film wrap to avoid evaporating.
I've even used a much less powerful creme in the past with a couple of cases and it worked quite well, no yellowing has returned so far.
Reply 15 of 22, by Kreshna Aryaguna Nurzaman
...so it is doable. 😳
Kreshna Aryaguna Nurzaman.
Reply 17 of 22, by Anonymous Freak
The main thing that retr0bright adds is a more "gel like" texture that makes it easier to spread and stay on the plastic. But now more beauty supply stores are selling gel hydrogen peroxide directly, so retr0bright's big advantage is just that it's cheaper to mix than to buy pre-made gel H2O2.
The oxyclean addition is meant solely as a "clean it while you're brightening it".
Reply 18 of 22, by Oldskoolmaniac
feipoa wrote:
If you don't add the UV light during treatment, does the yellowing come back a lot quicker?
Nope it wont make it worse, but u do have to use the uv to make the bromine react and then the peroxide cleans the bromine
