CVX4 : high quality covox adapter
Reply 440 of 484, by Scali
cvx4fanboy wrote:
Hello. I've got a CVX4 thing and cvxplay program. It does work and I can play sampleu.raw.
One thing I couldn't figure out yet is how to convert mp3 or wav to this covox raw format.
Could you please explain this to me?
You can use the free Audacity program for this: https://www.audacityteam.org/
Open your mp3 or WAV file, then use the Export function from the file menu. Export the audio as a mono 8-bit unsigned raw PCM file.
Reply 441 of 484, by matze79
you can play mp3 directly on cvx4 without converter. (at least Pentium required..)
Requires CWSDPMI:
http://sandmann.dotster.com/cwsdpmi/
    covoxmp3.exe
    100.93 KiB
    111 downloads
Reply 442 of 484, by matze79
if you want you can add Support to your Covox for FTL Sound Adapter.
Just adding a Wire gives you Sound in Dungeon Master.
Gave me some headattache but now i found out how it works..
Wire from Pin 17 to Pin 12 on your Covox Clone
77.06 KiB
And it works:
https://youtu.be/8-qID0qEmMs
    69.06 KiB
Reply 443 of 484, by shock__
Why would it? The FLT sound adapter is fully documented.
http://dmweb.free.fr/?q=node/1514 (schematic is kinda meh to read)
Current Project: new GUS PnP compatible soundcard
[Z?]
Reply 444 of 484, by matze79
Uff did not read this 😀
Reply 445 of 484, by Benedikt
Speaking of the FTL Sound Adapter...
That device uses a 25.5kΩ load resistor and I reckon the Speech Thing uses 25.5kΩ, as well. I'm therefore going to use 25.5kΩ for my own replicas (new thread).
MobyGamer's measurements strongly support this assumption:
MobyGamer wrote:
Well, that was educational: […]
CVX-1 Prototype: 5.04 vDC
CVX-2 Prototype: 4.80 vDC
10-pin Covox: 1.024 vDC
11-pin Covox: 1.025 vDC
With an input voltage of 5.04V and a 25kΩ load we should get an output voltage of
5.04V * (1 / (1 / 100kΩ + 1 / 25kΩ)) / 100kΩ = 1.008V
That is -1.5625% away from the 10-pin Covox and -1.6585% away from the 11-pin Covox.
With 25.5kΩ, however, we get
5.04V * (1 / (1 / 100kΩ + 1 / 25.5kΩ)) / 100kΩ = 1.02406374502V
That is just 0.0062% away from the 10-pin Covox and -0.0913% away from the 11-pin Covox. I'd call that bang on.
Reply 446 of 484, by matze79
i`m working on a combatibility list of covox software:
https://shadowcircuit.de/phpBB3/viewtopic.php?t=12
i test every piece by hand, so i`m 100% sure it works.
Reply 447 of 484, by konc
https://dosreloaded.de/forum/index.php/Thread … liste/?pageNo=1
That's great, I wish this forum wasn't in german 🤣
When you finish your project, could you also share the result here in vogons with a column on how to setup the application/game for covox?
eg Electro Man | setup option
Star control | cmd line param: /s:lpt<x>
Again, great idea
Reply 448 of 484, by matze79
yeah thats the plan 😀
but first i go straight trough mobygames list.
Reply 449 of 484, by dreamblaster
Did someone try CVX4 on a IBM PS/2 9577 ? Does this have 'special' parallel ports ?
I received a report, it didn't sound good on that machine.
Same CVX4 sounded great on his other PC.
Thanks for your support !
Reply 450 of 484, by MobyGamer
Remember that issue I had where the lack of a pull-up resistor meant the OPL3LPT device didn't work right on some of my systems? Do you think it might be related to this?
Also, the PS/2 Model 77 is microchannel; some software might not work correctly on it vs. regular ISA, EISA, VLB, or PCI systems. I'd ask him what software he was using to test it.
Reply 451 of 484, by digger
The list of games with Covox support will increase substantially when you include all the games that used AIL2 or DIGPAK drivers.
There is a DIGPAK driver for the Covox Speech Thing that can be used as an AIL2 driver as wel, simply by replacing an existing AIL2 DAC driver (for instance the Sound Blaster driver) with it, using a patch utility, or in the case ofsome games simply by overwriting the driver file with it, renaming the DIGPAK .COM file to the .ADV driver you're replacing.
Someone in another Vogons topic tought me that trick. Pretty neat. 😀
Reply 452 of 484, by dreamblaster
MobyGamer wrote on 2020-12-28, 19:28:
Yes it could be the same port difference, causing issues for CVX4.
Reply 453 of 484, by dreamblaster
Retiring the current revision of CVX4 to the museum.
If you still need current revision CVX4 or its enclosure, pm me.
(I have a few left for the bundle, which is still available at the moment)
I will make a new version CVX4 V2, later on.
Reply 454 of 484, by matze79
FastDoom Supports Covox now 😉
Reply 455 of 484, by ultramars
hello,
dreamblaster wrote on 2021-07-11, 11:04:
still available? what price?
Reply 456 of 484, by dreamblaster
ultramars wrote on 2022-02-01, 02:53:
hello,
ok i had a look, i still found a few CVX4 in my stock, and I added the bundle again to the webshop (only 2 times available) : https://www.serdashop.com/Special-Parallel-Port-Bundle
and I will also keep one CVX4 apart if you are interested, pm me.
I'm thinking of making a CVX5, any suggestions for changes/improvements compared to CVX4 ?
CVX5 would be available in larger amount, it will take a few months though
Reply 457 of 484, by ultramars
dreamblaster wrote on 2022-02-06, 09:18:
1) RCA connector(s) on all of your audio devices instead of minijack: it goes real quick to pull the cable out wrong or just accidentally pull on the cable, resulting in bad contacts with the minijack plug that has become too loose. This is less likely to happen with RCA's
2) from what i saw of the pictures of the casing of the OPL3LPT or MPU-232, those are more covers than protective casings: if you look at the shell of a DB25 plug, it's usually firmly attached to the connector itself, while on your designs, if anyone bumps/press on the device, the stress will be put on the circuit board and/or computer parallel port connector as it seems to me.
It would be great to have a rigid enough casing firmly attached to the parallel port & computer via the screws, to better protect the electronic circuit inside.
For the rest, i read the whole thread, heard the available listening examples and i guess everything has been pretty much thought about. The dip switches to switch between capacitors to adjust the lowpass filter cuttoff regarding of the sample rate versus mixer/amplifier's input impedance & cable inductance is a really great feature ! 😎
See this home brewed covox clone self contained in the DB25 plug shell AND with a RCA connector 😉
Reply 458 of 484, by digger
How feasible would it be to include Disney Sound Source compatibility in a CVX5 design?
I know you already mentioned that a DSS clone is in the pipeline, but having both Covox Speech Thing and DSS compatibility in a single device would be quite convenient, especially if it could somehow be made software-switchable between those two modes.
I recently acquired an original Disney Sound Source in a well working state. I'd be willing to lend it to you (long term even), if that would aid you in debugging and compatibility testing.
Reply 459 of 484, by FreddyV
The best would be to do a Disney sound Source like, With a bigger buffer and increased output frequency.
It is also possible to do a Parallel port "Covox" with DMA Support, as the parallel port support DMA.
