YMF724 under DOS problem
Reply 20 of 57, by j^aws
Okay, great.
I'm going to ask you to update a hidden file, so that troubleshooting is made much easier in DOS without affecting Windows. It is completely reversible, so don't worry.
From DOS, in C:\> Type:
attrib -h -s -r MSDOS.SYS
edit MSDOS.SYS
Now find where it says:
BootGUI=1
and change to:
BootGUI=0
Save MSDOS.SYS
And type in DOS:
attrib +h +s +r MSDOS.SYS
What you've done there is edited a hidden, read-only file, so that you boot straight into DOS without affecting Windows. Type WIN in DOS to boot into Windows.
Once you've done the above, we can test the card, and try some settings out. Please advise when you have done the above and can reboot straight into DOS.
Reply 21 of 57, by Deksor
Well, since the beginning, I made a shortcut to reboot in MS-DOS mode in windows 98, which has it's own autoexec.bat and config.sys. (a bit like Phil's Computer Lab did) Is it sufficient ?
While I do not type win or exit, when I reboot, the computer boots to DOS
Reply 22 of 57, by j^aws
For the purpose of troubleshooting, there are too many variables. You can go back to your method of switching to DOS later, if you prefer.
Please follow the above, and the setup will be easier to troubleshoot. And is more reminiscent of how Win3.1 and DOS 6.22 behaved. I'll ask you to change some BIOS settings that will affect how Windows behaves, so if you follow the above, you will never boot into Windows without typing WIN.
Reply 26 of 57, by j^aws
Okay, that's great.
Now on the following BIOS screen, where you change IRQs for Peripherals, keep the settings as they are, where you have already disabled Serial/ Parallel:
841.59 KiB
Now on the Power BIOS screen below, change to:
ACPI Function = Disabled
PM Control by APM = No
726 KiB
And for the PnP BIOS screen below, change to:
Reset Configuration Data = Enabled
Assign IRQ for USB = Disabled
PCI Slot 4 Use IRQ = 5**
IRQ-10 Assigned to = PCI/ ISA PnP
DMA 1 Assigned to = Legacy ISA
** I'm assuming you still have the YMF on Slot 4? If not, change the relevant Slot to IRQ 5
1.08 MiB
- When you have changed the above, save in BIOS and reboot straight to DOS.
- Please run Setupds, and post a screenshot of the utility.
So, what we've done is disabeld many IRQ hogs (we can enable later), and reserved for DOS:
IRQ 7 and DMA 1 for Sound Blaster.
IRQ 9 for SoftMPU MIDI.
IRQ 5 for PCI YMF724.
I'll continue when you have posted the Setupds screenshot.
EDIT: For the time being, don't boot into Windows.
Reply 27 of 57, by Deksor
Weird irq 😮
751.79 KiB
Here is the pnp bios
1.16 MiB
Reply 28 of 57, by j^aws
Deksor wrote:
Weird irq 😮
I've seen this IRQ 127 before, where the utility is confused. It is fixable.
Please go into the utility by running Setupds, and post a screenshot of the utility. I'll continue after this.
Reply 29 of 57, by Deksor
1017.54 KiB
The grey doesn't appear to be readable with my phone's camera ...
So it's written from top to bottom in grey color : "IRQ channel : inta#" "irq channel : inta#" "inta# irq : 127" d-dma base : 8000"
When I set IRQ mode to S-IRQ, here how it looks :
948.65 KiB
Reply 30 of 57, by j^aws
Okay, were going to reset the card.
Change to:
Legacy Audio = Disabled
Then Save and Exit.
Do a full power reboot back into DOS, and run Setupds /s.
Post the output screenshot after this. Then I'll continue.
Reply 31 of 57, by Deksor
771.16 KiB
946.92 KiB
Obviously everything was desactivated in the first place, but I activated it so you can read it (again, poor image quality due to bad camera)
I'm waiting your answer, I presume it will work, but I don't want to ruin everything ^^
Reply 32 of 57, by j^aws
Okay, change to:
SB PORT, IRQ CHANNEL = 7
MPU PORT, IRQ CHANNEL = 9
- Test and Save.
- Do full power reboot, run Setupds /s.
- Print output screenshot.
Test games with Sound Blaster IRQ as 7, DMA as 1. Ensure game setup options are updated to this.
There are a few more things I need to check after this. I'll continue then.
Reply 33 of 57, by Deksor
Yikes, I still can't save
869.27 KiB
921.2 KiB
Reply 34 of 57, by j^aws
There are a few more things we could try.
One of them, I think the board doesn't like PCI Slot 4.
Change the card to another PCI Slot, e.g. Slot 3.
Update BIOS, so change to:
PCI Slot 3 Use IRQ = 5
PCI Slot 4 Use IRQ = Auto
Then follow what we did after the last BIOS Save.
Report back.
Reply 35 of 57, by Deksor
Whew, this was thight, the sb_link header is almost touching the voodoo 2 which is now just underneath, but it fits
But it still doesn't want to work ...
909.94 KiB
