Reply 40 of 61, by superfury
I just took a little crack at trying to implement the PDM replacement for PWM. The output doesn't seem to match though(it might still have some basic signal processing problem).
byte WAVEFORM_OUTPUT[16][16] = { //PDM Waveforms for a selected output!#ifndef PDM_OUTPUT//PWM output?{0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0}, //Volume 0{1,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0}, //Volume 1{1,1,0,0,0,0,0,0,0,0,0,0,0,0,0,0}, //Volume 2{1,1,1,0,0,0,0,0,0,0,0,0,0,0,0,0}, //Volume 3{1,1,1,1,0,0,0,0,0,0,0,0,0,0,0,0}, //Volume 4{1,1,1,1,1,0,0,0,0,0,0,0,0,0,0,0}, //Volume 5{1,1,1,1,1,1,0,0,0,0,0,0,0,0,0,0}, //Volume 6{1,1,1,1,1,1,1,0,0,0,0,0,0,0,0,0}, //Volume 7{1,1,1,1,1,1,1,1,0,0,0,0,0,0,0,0}, //Volume 8{1,1,1,1,1,1,1,1,1,0,0,0,0,0,0,0}, //Volume 9{1,1,1,1,1,1,1,1,1,1,0,0,0,0,0,0}, //Volume A{1,1,1,1,1,1,1,1,1,1,1,0,0,0,0,0}, //Volume B{1,1,1,1,1,1,1,1,1,1,1,1,0,0,0,0}, //Volume C{1,1,1,1,1,1,1,1,1,1,1,1,1,0,0,0}, //Volume D{1,1,1,1,1,1,1,1,1,1,1,1,1,1,0,0}, //Volume E{1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,0} //Volume F#else//PDM output?{0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0}, //Volume 0 Same as PWM{0,0,0,0,1,0,0,0,0,0,0,0,1,0,0,0}, //Volume 1 TODO(+2){0,0,0,0,1,0,0,0,0,0,0,0,1,1,0,0}, //Volume 2 TODO(+3){0,0,0,0,1,1,0,0,0,0,0,0,1,1,1,0}, //Volume 3 TODO(+5){0,0,0,0,1,1,1,0,0,0,0,0,1,1,1,0}, //Volume 4 TODO(+6){0,0,0,0,1,1,1,0,0,0,0,0,1,1,1,1}, //Volume 5 TODO(+7){0,0,0,0,1,1,1,1,0,0,0,0,1,1,1,1}, //Volume 6 TODO(+8){1,0,0,0,1,1,1,1,0,0,0,0,1,1,1,1}, //Volume 7 1H 3L 4H 4L 4H confirmed(+9){1,1,1,1,0,0,0,0,1,1,1,1,0,0,0,0}, //Volume 8 4H 4L 4H 4L confirmed(+8){1,1,1,1,0,1,0,0,1,1,1,1,0,0,0,0}, //Volume 9 4H 4L 4H 4L(+9){1,1,1,1,0,1,0,0,1,1,1,1,0,1,0,0}, //Volume A TODO(+10){1,1,1,1,0,1,1,0,1,1,1,1,0,1,0,0}, //Volume B TODO(+11){1,1,1,1,0,1,1,0,1,1,1,1,0,1,1,0}, //Volume C TODO(+12){1,1,1,1,0,1,1,0,1,1,1,1,0,1,1,1}, //Volume D TODO(+13){1,1,1,1,0,1,1,1,1,1,1,1,0,1,1,1}, //Volume E TODO(+15){1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,0} //Volume F Same as PWM#endif};
Have I done this correctly? Volume 8&7 are taken directly from your comments. The others I've tried to average roughly myself(I hope I did it correcly, trying to keep in mind to make the ones count a bit more than the zeroes)). Is this somewhat in the right direction?
UniPCemu Git repository
