WIP versions
Reply 581 of 1111, by lowenz
ZellSF wrote:
GLDirect Seems to just crash. […]
GLDirect
QindieGL
Works with resolution forcing. I can't find any use cases for this though.
You seriously want to wrap a wrapper 😐 🤣!
Reply 582 of 1111, by ZellSF
lowenz wrote:
GLDirect
QindieGL
The attachment aaa 2018-10-28 13-07-54-43.jpg is no longer available
Not at the moment, since DxWnd handles all OpenGL games better than GLDirect or QindieGL, but I might actually eventually run into a game where I would want to.
Armies of Exigo
D3D9. Seems to work as it should with all nice extra features enabled. Should stick to integer factors when resolution forcing.
1.42 MiB
X-Men Legends II: Rise of Apocalypse
D3D8 (a lot of games I thought were D3D9 turns out to be...). Also looks perfect, benefits from resolution forcing since this has poor text scaling at higher resolutions.
283.94 KiB
Reply 583 of 1111, by CoolGamer
ZellSF wrote:
Halo
We have detected that one of the Halo PC files is missing or corrupted. We recommend removing and reinstalling the game. (shaders\fx.bin).
Pretty sure this requires shader model 2.0, though the log does not mention it.
I remembered something about Halo. Halo Combat Evolved has Directx 8 (PS 1.4 and PS 1.1) and Direct 7 (T&L) level rendering paths for old GPUs that do not support Pixel Shader 2. I wrote the links for the Demo and Technical Document that lists command line options below.
https://download.cnet.com/Halo-Combat-Evolved … 4-10235611.html
https://www.ign.com/faqs/2003/action-double-p … ical-faq-456511
In summary, the command line options are the following:
halo.exe -useff (directx 7 T&L)
halo.exe -use11 (directx 8 PS 1.1)
halo.exe -use14 (directx 8 PS 1.4)
halo.exe -use20 (directx 9 PS 2.0)
Halo always needs/uses d3d9.dll in all of these modes, but it simply uses a lower feature level.
I could NOT get dgVoodoo WIP52 to work with Halo Combat Evolved PC Demo in any of these rendering paths on my laptop. 😢 There might be issues other than PS 2.0 compliance when running Halo via dgVoodoo. Either way, Halo Combat Evolved PC demo can be used to debug pixel shader compliance issues since it allows multiple Directx rendering paths.
Half-Life 2 demo also had a similar mechanism. It had developer console commands that allowed setting directx level to 6/6.1/7/8/8.1/9.0/9.0+/9Ex.
https://developer.valvesoftware.com/wiki/DirectX_Versions
Half-Life 2 console commands are:
"mat_dxlevel 60", "mat_dxlevel 61", "mat_dxlevel 70", "mat_dxlevel 80", "mat_dxlevel 81", "mat_dxlevel 90", "mat_dxlevel 95", "mat_dxlevel 98"
I haven't downloaded and tested Half-Life 2 demo from Steam with dgVoodoo WIP52 yet. Either way, Half-Life 2 demo should also be a good demo to test DirectX compliance since it supports all directx levels. 😀
Reply 584 of 1111, by ZellSF
Half-Life 2
The procedure entry point D3DPERF_SetOptions could not be located in the dynamic link library D:\Steam\steamapps\common\Half-Life 2\bin\shaderapidx9.dll.
kill.switch
D3D9. Works. Resolution forcing works too, but probably pointless.
356.56 KiB
The Matrix: Path of Neo
Crashes. Config ini file says game has shader model 1.x support.
TrackMania
D3D9. Works. Resolution forcing creates mouse issues. Maybe more interesting is that if shadows are enabled, the game will crash at loading the 3D engine.
576.59 KiB
Turok Evolution
D3D9. Works. Resolution forcing doesn't, which is too bad since it would help a bit here (see the small health font).
757.79 KiB
Ys: The Oath in Felghana
876.39 KiB
Reply 588 of 1111, by ZellSF
Project Snowblind
D3D9. Works. Resolution forcing works too, but probably pointless. Antialiasing creates problems. Seems to perform worse than native with framerate drops being more noticeable.
393.96 KiB
Reply 589 of 1111, by Deffnator
F-22 Lightning III
-with the latest patch, the graphic settings keeps reseting to 640x480 if using ddraw with fullscreen
Warhammer: Dark Omen
-crashes and bad resolution flickering, 3d is a no go
Diablo 2
-Strange Lines and outlines if using Anisotropy filtering
Star Wars: Tie Fighter 98
-2 mouse cursors
Wing Commander IV GoG/Origin DVD edition
-Still has the same bugs that i said it, but now the menus works well with MS warp + Legacy stock rendering, but is slow as fuck, the game and dgvoodoo enters on a full flegded tug of war to see who rules it 1st, and it becomes incredibly slow with the game changing between stock and dgvoodoo every time when it flickers or opens a menu.
Reply 590 of 1111, by teleguy
-2 mouse cursors
Usually happens when you force higher resolutions. One is the game's original cursor confined to a 640x480 box, which is the game's stock resolution.
Should be fixable by adding the command line switch -softwarecursor to the game or by enabling it from the launcher.
Reply 591 of 1111, by Gamecollector
ZellSF wrote:
Spellforce doesn't look for d3d9.dll in its directory, just C:\Windows\SysWOW64, and since you obviously can't replace the system d3d9.dll you need to edit Spellforce's exe to point to something else.
Try dll redirection.
Reply 592 of 1111, by lowenz
The same for Aquamark 3
@Dege, How is this even possible? Dege's D3D9 totally wins the comparison!
Reply 593 of 1111, by lowenz
lowenz wrote:
The same for Aquamark 3 […]
*REMOVED*
It's the NVidia profile! Renaming the exe, I finally got expected results!
Reply 594 of 1111, by RJ8
EDIT: Ive tried that with Spellforce, it seems that DGVoodoo doesnt recognize the redirection. ... For that rare case with Spellforce editing the exe doesnt take away much more time then creating folders ect.
anyhow Thanks for the hint on DLL Redirection
Request a game profile for VorpX - VorpX Inofficial Gamelist - RJs VorpX Games
Reply 595 of 1111, by ZellSF
Cold Fear
D3D9. Works. Antialiasing and forced resolution breaks shadows. Performance problems (framerate dips). Limited to "Low" lightning details.
335.12 KiB
Kohan II: Kings of War
ERROR: This hardware does not appear to support rendered textures, which are required for this game.
Reply 597 of 1111, by ZellSF
Myloch wrote:
I thought d3d9 era games were not resolution limited but oh well...
When the game was made is pretty irrelevant to whether or not it is resolution limited (disregarding of course the ddraw 2048x2048 limit).
Cold Fear has a preset resolution list with 1600x1200 being the max, but there's a widescreen hack available for it that lets you set whatever resolution you want.
Zoo Tycoon 2
D3D9. Works. "Emulated" modes (aspect ratio correction, forced resolution) have too many mouse issues. Resolution forcing is pointless for this game anyway.
851.35 KiB
Reply 598 of 1111, by RJ8
Cursed Mountain (Adventure from 2009)
- Game is running
- Resolution can be forced
- Graphics look like 16 bit, textures have funny RGB colours
    120.62 KiB
Reply 599 of 1111, by willow
So Blonde directx 9c game
Firts video with anaconda logo: black screen and sound works.
Second video with wizard box logo: works
If I try to force resolution or use scaling method: centered or stretched with keep aspect ratio, I have this error
Force aa 8x and af 16x seems works very well.
