WIP versions
Reply 600 of 1111, by RJ8
Sudeki
Manga/Hentai Style Action RPG, Hack n Slay
- Shader 1.1
- Working
- Shadows must be disabled
    1.6 MiB
Request a game profile for VorpX - VorpX Inofficial Gamelist - RJs VorpX Games
Reply 601 of 1111, by ZellSF
GUN
D3D9. Works. Resolution forcing works (but pointless). Antialiasing creates some minor issues.
437.98 KiB
History Channel: Crusades
D3D9. Works. Antialiasing and resolution forcing works (but pointless). Movies don't work (the game skips them automatically when running with dgVoodoo).
570.19 KiB
Riot Police
Same engine as Histoy Channel: Crusades so works sort of similarly. Except resolution forcing doesn't work. There were other non-dgVoodoo compability issues with both these games I couldn't figure out.
513.29 KiB
The Bard's Tale
D3D9. Works. Antialiasing and resolution forcing works. Will fix the bad UI scaling in this game, but most people are probably better off with the "remastered" version on Steam which also fixes UI scaling. The remastered version also runs with dgVoodoo.
383.2 KiB
Reply 602 of 1111, by lowenz
Unreal Gold with lastest build (not released yet) of the oldunreal patch 227j:
NaliCastle Flyby / windowed mode 1280x960 / No Sound / No AA
(no AF)
MS DDRAW: 560 FPS
Narzoul DDRAW: 510 FPS
Dege DDRAW: 530 FPS
(AF 16x)
MS D3D8: 510 FPS
UCyborg-hacked MS D3D8: 510 FPS
Dege D3D8: 540 FPS
(AF 16x)
MS D3D9: 750 FPS
Dege D3D9: 680 FPS
Reply 603 of 1111, by roshiahito
The Guild 2 (wikis say it supports Shader Model 1.x):
Attached debug log.
Apitrace: https://drive.google.com/open?id=1QktfV-HOgqO … 0CksISPgZP0vA3u
    guild_dgvoodoo2_dbg.log
    1.88 MiB
    111 downloads
Reply 604 of 1111, by RJ8
Armies of Exigo
- Seems to work excellent with forced resolution
    355.82 KiB
Reply 605 of 1111, by RJ8
Brothers in Arms: Road to Hill 30
- Unreal 2.5 Engine (Shader 1.?)
- DGVoodoo hooking
- Heavy stutter with Audio gaps and mouse cursor movement related to audio gaps
- Black screen when actually starting game
Reply 608 of 1111, by batterymandark
I was excited to see if I could get AvP classic 2000 to work with dgvoodoo /w DirectX 9 support.
so an forced upscaling could make the text readable, but it seems that when loading a level I just stays in game resolution
https://1drv.ms/u/s!Agj8jUvjAJjzoSrnjqZKIr-dM2M2
Diablo , even after latest patch, refuse to create a screen-size, the only way to make it work is to untick application behavor fullscreen and untick disable alt-tab
however game refuses then to stay fullscreen and pop back to windowed and alt enter wont help
https://1drv.ms/u/s!Agj8jUvjAJjzoStbgdvMNdjqUEo_
The sims 1 collection, refuses sometimes to start, says gpu doesn't support 65535 colors, and if compatibility is set to 16 bit color, a double mouse appear if the game is upscaled.
I couldn't get an image of double mouse since on the screenshoot only shows one mouse cursor as if the game ran normal.
Reply 610 of 1111, by RJ8
Reporting Breed as nicely working with the DX9Wrapper.
    370.84 KiB
Reply 611 of 1111, by stranno
Reservoir Dogs. Character models are corrupted with two or three animations displayed at the same time. Every other thing seems to work properly but i havent played much so i could be wrong.
A fix for this game could be a good adition since it has fixed 4:3 and 16:9 resolutions (1440x900 or something like that in 16:9).
Unfortunately the port sucks and it runs at ... i'd say locked 20 frames per second, who knows why. So it will remain pretty much unplayable even with fixed graphics.
Reply 614 of 1111, by RJ8
Dungeon Siege 2 (DX9, supposably shader 1.X)
-not completely crashing , DGVoodoo Logo appears, then window goes into background, exe remaining in task manager
-DEBUGVIEW: [3948] [dgVoodoo] INFO: DDRenderWindow (05F5E630): Rendering window (608e6) is deactivated.
Reply 617 of 1111, by ZellSF
CivCity: Rome
D3D9. Needs shader version set to 0.0 to get ingame with very glitchy rendering: https://www.youtube.com/watch?v=rykdXuBFROc
Desert Rats vs. Afrika Korps
D3D9. Works. Emulated modes gives double cursor, but resolution forcing is unnecessary for this game anyway.
634.81 KiB
War Times
D3D8. Works. Resolution forcing does not (game sets resolution regardless of dgVoodoo setting). Makes some complaint about non-power of two resources, but there's a patch available.
573.59 KiB
Reply 619 of 1111, by batterymandark
never think I would see this day. Oni running on Qindie that's runs on dgvoodoo
I know that Light Coronas in Oni doesn't work with Qindie , but its cool to see that maybe there is hope on day to get small ui on opengl games readable again with hi-res monitors.
y4mKKzYdrLw16Vxbo16MGElWbD73pMkpuDKfyiUYnJX1RvCCn78zVaNiGQyoHm72I5BzdwBP8Ju2Tr9RAmhF8vjBYleBz54XDUjHTkkpuyGWf3yMlSGzfCca_YR5rRUHjy_JWav9iXlNuT1JqUNr3CP7yXBPEtWAAA0cIptVX-xgshglg0SXWshaUaSPYlHs6Ov?width=1920&height=1440&cropmode=none
