WIP versions
Reply 722 of 1111, by RJ8
Rise of Legends Realtime Strategy / 2006
Not shure which shader model the game has, but works with wip53 (Shadows look weird, turning them OFF solves the problem)
Request a game profile for VorpX - VorpX Inofficial Gamelist - RJs VorpX Games
Reply 723 of 1111, by ZellSF
Sacred 2
Lots of rendering problems. Also sort of bad performance.
951.35 KiB
868.35 KiB
1.05 MiB
dgVoodoo debug version seems to have less problems but might be just my imagination.
Reply 724 of 1111, by luigi-master
I posted something but it's gone.
TMNT 2003:
https://i.imgur.com/RJFMpCi.png
Just like the demo version, the retail version has texture issues. The game world looks fine.
Total Overdose:
https://i.imgur.com/CYAJKEQ.png
https://i.imgur.com/mpogarD.png
The world is green.
Does anyone know how to get thirteenag's widescreen to fix with Total Overdose? I'm using the retail version but dragging and dropping things doesn't seem to work, the game refuses to boot.
Reply 727 of 1111, by ZellSF
Alias: The Game
Works, but complains that it can't create VMR9 instance whenever it tries to play videos (native is fine) and requires some weird modes added to ExtraEnumeratedResolutions, playing at 1280x720 i had to check the log to find this:
ERROR: Direct3D9 (0BC2E7B8): Validation of D3D9 swapchain presentation parameters failed. Reason: display mode "1276x716, 60Hz" is required but not supported by output device: 0, DeviceType : D3DDEVTYPE_HAL
Like it somehow ended up trying to compensate for window borders while setting display mode. Adding that as a supported resolution and:
115.3 KiB
Reply 729 of 1111, by Dege
Yeah, that seems to be more than a single 'lag'.
I've put a lot of effort into avoiding lagging/stuttering caused by shader compositing.
It's not perfect because not every case can be handled well, but games like FEAR, Lego Star Wars, etc. are now running pretty smooth. So, we'll see.
BTW, an other thing is tending to be needed for more and more games: float textures and rendertargets. I think I'm going to implement them.
Reply 731 of 1111, by ZellSF
OK, I've made sure I'm using a stock config for F.E.A.R now and found a glitch.
Native:
42.23 KiB
dgVoodoo2:
41 KiB
Think it happens with all walls.
Reply 732 of 1111, by syhlif32
Works great in the race sim games I care most about GTR2 and GTL. Reflection are better sky and lights looks better only the rain fog is missing so kind of clear while raning.
Race 07 got issues due to a shadow Zbuffer but the shaders can be disables.
AMS (Automobilista) kind of works the sky is black. No textures rendered
Any chance to get 2048 and 4096Mb Vram?
Larger tracks slow down quite a lot.
Reply 734 of 1111, by syhlif32
You can type in whatever value you want.
Thanks didn't know that.
Can't get it to accept higher than 2048Mb. Got 8192Mb
Not even sure it helped but have left it at 2048Mb anyway.
Reply 735 of 1111, by RJ8
Armed Forces Corp City Interactive shooter , working with WIP53 ( Many City Interactive Game crash with a black screen, if you run into that follow this
Reply 737 of 1111, by Expack3
World of Goo (Humble Bundle version 1.30), a DX7/9 game, works flawlessly with WIP53, though it doesn't truly benefit from resolution scaling.
The game uses a mix of DX9 and DX7; running without the DX7 DLLs results in a fatal error, and running with just the DX7 DLLs prevents dgVoodoo2 from hooking.
EDIT: Forgot to mention the "FreeMouse" variable must be true in either the global or local dgVoodoo2 config file; otherwise, the mouse is locked to the pre-scaled resolution.
Reply 739 of 1111, by Expack3
lowenz wrote:
Good catch! But why?
The FreeMouse variable has to be set somewhere. If the user hasn't setup a dgVoodoo2 config file in the game's directory, then the global dgVoodoo2 config file has to be edited. The latter is woefully inefficient (what if the user has more than one game dgVoodoo2 hooks?), but I thought I'd mention it for completeness.
