Crazy Idea - MT32 WaveBlaster Card
Reply 40 of 100, by gdjacobs
RJDog wrote:
PhilsComputerLab wrote:
If it's ok with you, I can merge with the existing "Munt on Pi" thread and move it to Sound?
Yeah, I followed that thread pretty closely; definitely good work. My attempts here are to essentially productize that idea into a unique form factor. I don't disagree with merging the two... for sure both belong in Sound.
That's my thinking as well. I want to create a synth module capable of mounting in a drive bay or on the desk that can handle all LA synth or sample based synthesis.
Reply 41 of 100, by hard1k
MuntBlaster?..
Fortex, the A3D & XG/OPL3 accelerator (Vortex 2 + YMF744 combo sound card)
AWE64 Legacy
Reply 46 of 100, by hard1k
gdjacobs wrote:
LABlaster?
BLABLAster 😁
AWE64 Legacy
Reply 48 of 100, by brostenen
M-Daughter-32
Reply 49 of 100, by RJDog
hard1k wrote:
MuntBlaster?..
MB-32
MB-32 = MuntBlaster-32
32 because... Cortex A7 is 32 bit processor.... I guess
Sold! (or until something better comes to mind)
Reply 50 of 100, by RJDog
First draft of the WaveTable-to-OrangePiZero card complete; the host board (i.e. the board this card will go in to make it a stand-alone unit) yet to come.
    52.7 KiB
Reply 52 of 100, by hard1k
Maybe I will be totally wrong here (as I'm not a hardware design engineer), but looking at the Orange Pi Zero picture the lower 26-pin header ("expansion port") on the MB-32 seems to be misplaced by 1 pin to the left - judjing from mutual placement of this header and the serial debug port as well as its alignment against the upper 13-pin "function interface".
AWE64 Legacy
Reply 53 of 100, by RJDog
Holy buckets of earth, batman! You are exactly correct... good catch. Now I feel like an idiot. Not sure how I screwed that up so badly in the footprint...
Reply 54 of 100, by hard1k
Don't worry, that happens 😀
When we produced the first batch of the GUS PnP RAM Adapter, somehow we chose the wrong thickness for the PCB - 0,8mm instead of 1,0mm. We had to manually add additional solder to the contacts in order for the adapter to sit well in the SIMM sockets, otherwise they just fell out...
You're welcome 😀
AWE64 Legacy
Reply 55 of 100, by RJDog
Well... here is the updated version, this time with the correct footprint for the Orange Pi Zero. Still working on the host board. Thanks again, hard1k, for catching the misalignment.
    55.04 KiB
Reply 57 of 100, by RJDog
Ariakos wrote:
This is a neat project. But the things I would do for an MT-32 in a PCMCIA form, though... 🤑
Well.. there do seem to exist PCMCIA MIDI cards....
But in other news, I have discovered a critical error in my design... my current design is based on the assumption that the Orange Pi Zero accepts 5V on the GPIO. It does not. It is 3.3V and apparently is not super tolerant of higher voltages. I'll have to rethink this.. implement a logic level converter or something...
Reply 59 of 100, by RJDog
Yeah, the MOSFET route seems to be a bit on the expensive side, but doable, and quick googling seems to indicate its a popular solution.
I am thinking about using some non-inverting buffer logic chips, i.e. the 74LV125A can operate at and output 3.3V but inputs accept up to 5.5V regardless of Vcc; and 74HCT125N can operate at and output 5V and inputs accept as low as 2.1V for "high" signal. My biggest concern would be to make sure the buffers can switch fast enough to accomodate the 31250 baud rate. The TI part I'm looking at says its switching time is 4.7ns, which equates to roughly 2MHz, so that should be okay, I think?
