First post, by member
HI
it's about pcb mark ing on the Motherboard Temperature Sensor Locations Negative temperature coefficient (NTC) Thermistors Chip place s by brand name s
Ambient (aka chassis) Thermal Sensor is located at the lower left corner of the motherboard, directly under the "Super I/O" chip and have code TRMB1 😎 Thermal Resistor Mainboard 1
20.57 KiB
https://www.google.bg/url?sa=t&rct=j&q=&esrc= … JPSyMXZ2_L6nhMw
ASROCK K7S41GX 😎
115.45 KiB
Service Manual 😎 http://www.s-manuals.com/motherboard/gigabyte_ga-8i915me-gl
Gigabyte pcb code is RS- RESISTOR SYSTEM
62.98 KiB
192.65 KiB
Asus P3B-F REV. 1.04 pcb code is RT1;2 Resistor Thermal
230.86 KiB
Multilayer NTC Thermistors Series: ERTJ0ER682 😎
Reply 1 of 8, by member
165.56 KiB
Elitegroup Computer Systems.
K7AMA2 (V2.0) 😎 (NTC) Thermistor pcb code is RT1;2 😎 PCB With VIOLET Mask Ink
HERE how bios show that bios_2_2.jpgsShowImage?id=4A299E7F-CC5D-1B5A-282B-4D8E9915CEE8.png1431589_f520.jpg and on CPUID HWMonitor
188.08 KiB
http://www.aoaforums.com/forum/epox-motherboa … r-location.html
i search for other brand s pcb code on systems sensor
do you help me 😎
Reply 2 of 8, by member
124.42 KiB
ON the asus p2b-b is code d RT1R
155.91 KiB
Reply 3 of 8, by member
121.96 KiB
Foxconn 648FX7MF
ECS RS485M-M
121.96 KiB
    159.46 KiB
Reply 4 of 8, by member
170.47 KiB
ASUS P5GC-TVM 😎http://webcache.googleusercontent.com/search? … g&ct=clnk&gl=bg 😎 https://www.google.bg/maps/@22.7208787,120.30 … !7i13312!8i6656
Reply 5 of 8, by member
The X540 incorporates an on-die diode3500Fig01.gifcan be used to monitor the die temperature
(junction temperature). An external thermal sensor located on the motherboard or a
stand-alone measurement device can be used to monitor the die temperature of thex540-ethernet-family-16x9.png.rendition.intel.web.416.234.png
X540 for thermal management or characterization. Table 12-4 lists the parameters that
pertain to the X540's thermal diode pins (THERM_D1_P, THERM_D1_N)dell-intel-x540-t2-dual-10gb-10g-10gbe-10base-t-rj45-ethernet-pci-e-3dfv8-hh-41931-p.jpg.
    204.42 KiB
Reply 6 of 8, by member
SSD WITH 4 T. SENSORS http://www.tomshardware.com/reviews/ssd-910-b … nce,3226-2.html
