First post, by cj_reha
Hi,
I just got a PC off of eBay with a generic Socket 7 motherboard in it. The chipset is apparently from PC Chips.
Can someone send me a manual and/or give me the model of the board? Thanks 😁
I also made a post about this PC in the bought retro hardware thread but I think this deserves its own thread 🤣
    3.03 MiB
    3.94 MiB
Reply 1 of 5, by Deksor
Often just typing the POST string on google helps to find which board you have 😀
For award bioses it's on the first screen (or second if you gpu displays something first during initialisation) at the bottom left. For AMI bioses (that seem to be common on PC chips board) I don't really know but I'm pretty sure it's written somewhere. Often there is the name of the northbridge in that string (it can be faked though)
Edit : nevermind for AMI bios, it's written a big "AWARD BIOS" on your rom chip so you don't need to care about how it works for AMI ^^
Reply 2 of 5, by Skyscraper
I would guess its a Matsonic MS-5120 also called PC-Chips M547 and if so it uses a VIA Apollo VPX chipset which is decent.
Here is the manul
Matsonic ms5120.zip
175.28 KiB
124 downloads
Reply 3 of 5, by cj_reha
Here is the manul
Matsonic ms5120.zip
Close! The bios string reveals it's a M537DMA33.
Reply 4 of 5, by man-x86
Here's the archive I used when I rescued the same motherboard from the trash. There's a bit of documentation, some advices for upgrading to a K6-2 and a couple of BIOS dumps.
I hope that helps 😊.
    m537dma.zip
    1.24 MiB
    178 downloads
    PCChips M537 bios + manual
Reply 5 of 5, by Skyscraper
cj_reha wrote:
Here is the manul
Matsonic ms5120.zip
Looking at the picture at http://motherboards.mbarron.net/models/pcchips/m537dma.htm your board does not look like the M537DMA33 but it does look exactly like the picture of the Matsonic MS-5120 shown in the manual I posted. 😀
I guess the picture of the M537DMA33 on the mbarron site could be wrong but I do not think it really matters because the boards probably share BIOS as they are both PC Chips (Hsing Tech) made boards with the same chipset from the same time.
In any case use the M537DMA33 BIOS as it evidently works and have the same BIOS identification string as your current BIOS which will make the BIOS flash work without trickery. When it comes to jumper settings you need to follow the instructions for a board with the exact same layout as your board.
