First post, by cj_reha
I recently bought a 386 off of eBay without a harddrive but guaranteed to POST. After attempting to test the front keyboard port, it has stopped responding to the keyboard and I'm afraid I may have damaged/shot the keyboard controller on the board. I was able to get into PhoenixBIOS earlier when it reported a CMOS error but now it locks up after the memtest, with just a blinking cursor. I'm able to skip the memtest by pressing keys, it then says "Memory test disabled by keyboard stroke", but I cannot get anywhere else.
It also used to probe for floppy drives shortly before reporting a CMOS error. The first time it probed, it went slowly but the next few times before the problem appeared the drives seemed to grind a lot faster. Now it doesn't probe for them, it just locks up. It's weird..
It's an Asus CACHE386/33 board with the Intel 386DX-33 installed as well as a Cyrix FasMath copro installed. There's 8 MB of RAM on the external cache board.
Does anyone know if I could somehow boot into BIOS? I'd like to make sure I didn't just kill the keyboard controller. I didn't ever hotplug it, but maybe I plugged it in wrong? I don't know...
Reply 1 of 10, by chrismeyer6
Did you try a absolute barebones test minimum ram and hardware to see if it'll post. How's the bios battery as well some older systems act funny when there dead or almost dead.
Reply 3 of 10, by cj_reha
The system came with a dead 3.6volt external battery installed. Don't have one on hand, but just tried hooking it up again to see if it was just because it couldn't find a battery. No change.
Removed the 3com Ethernet card and left only the video, I/O cards, and the RAM board in there. No change.
The RAM board's slots had super brittle plastic holders holding the RAM in so I didn't take any out. But reseating the board didn't help.
Removed I/O cards so it was just the VGA card and the RAM board. Nothing.
Reply 4 of 10, by cj_reha
Brickpad wrote:
Have you tried disconnecting the keyboard lock (if there is one) ?
There's a keyboard lock on the case, yes. Removed the connector from the motherboard, nothing. It's in the unlocked position, anyways.
I also just noticed it checks the memory and then restarts and checks it again instantly. Weird.
I performed the keylock test with both the I/O cards inserted and out.
Both retained nothing. 😕
Reply 5 of 10, by chrismeyer6
i would try the board again with a fresh battery i have a few older boards that wont post without a good battery or some that will act really strange
Reply 6 of 10, by Jo22
Good idea, because some real-time clocks get entirely powered by the battery.
Whithout one, the clock's CMOS RAM is inaccessible (dead), too.
Reply 7 of 10, by Anonymous Coward
Replace the keyboard fuse. It's usually a little round yellow cylinder that looks a bit like a diode. They're usually located very close to the keyboard port. You can easily test it with a multi-meter.
Reply 8 of 10, by cj_reha
You mean that little fuse above the port?
    3.21 MiB
Reply 9 of 10, by Brickpad
Yes, that's the one. Hard to tell for sure, but if that's glass, it looks like it's fogged, indicating a blown fuse.
Reply 10 of 10, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
Doubt a broken fuse would let you do this:
Check the fuse with a multimeter before replacing. You can also check the keyboard data lines with the multimeter in diode test mode. Parasitic diodes should be present between each data line and 5V / GND. If a data line is shorted to either it's not good.
How long did you wait after the lock up? Some errors take some time to show up.
Further things you can do:
- replace the dead battery
- check jumper settings, if any
- re-seat socketed chips
- try without copro and cache disabled
- check for chips producing excessive heat
- check for conductive debris on the board / in the slots
- POST card
- other power supply
1+1=10
