jmarsh wrote:Set output to opengl (or openglnb) as well.
I messed with this some more. For some reason, I can't get it to stretch the full width of the screen. opengl does "blend" the graphics a little better though.
igermi wrote:
One thing I notice (on windows with ECE) it almost seems like the volume in the game changes a little from time to time, without me adjusting it. I don't see a setting enabled (by default) that would do this. Has anyone else noticed this?
igermi wrote:jmarsh wrote:Set output to opengl (or openglnb) as well.
[sdl]
fullscreen=false
fulldouble=false
fullresolution=1920x1080
windowresolution=960x720
output=surfacenp
surfacenp-sharpness=0
autolock=true
sensitivity=100
waitonerror=true
usescancodes=true
priority=higher,normal
[dosbox]
machine=svga_s3
memsize=16
[render]
frameskip=0
aspect=true
scaler=none
[cpu]
core=dynamic
cputype=auto
cycles=fixed 29400
#cycles=max 70%
cycleup=10
cycledown=20
[mixer]
nosound=false
rate=48000
blocksize=2048
prebuffer=80
[midi]
mpu401=intelligent
mididevice=fluidsynth
midiconfig=
fluid.soundfont=.\8MBGMSFX.SF2
fluid.gain= .25
[sblaster]
sbtype=sb16
sbbase=220
irq=7
dma=1
hdma=5
sbmixer=true
oplmode=auto
oplrate=48000
oplemu=default
[gus]
gus=false
gusrate=44100
gusbase=240
gusirq=5
gusdma=1
ultradir=C:\ULTRASND
[speaker]
pcspeaker=false
pcrate=44100
tandy=auto
tandyrate=44100
disney=false
[dos]
xms=true
ems=true
umb=true
keyboardlayout=US
files=50
[joystick]
joysticktype=none
timed=true
autofire=false
swap34=false
buttonwrap=false
[serial]
serial1=dummy
serial2=dummy
serial3=disabled
serial4=disabled
[autoexec]
@echo off
SET PATH=Z:\
keyb US 437
mount C ".\VirtualC\" -freesize 2162
imgmount D ".\ISO\Angel_1.cue" ".\ISO\Angel_2.cue" ".\ISO\Angel_3.cue" ".\ISO\Angel_4.cue" -t iso -fs iso
echo.
C:
cd angel
angel.exe
Qbix wrote:maybe check this topic:
viewtopic.php?f=31&t=66491
So far we haven't seen a real cause. DOSBox seems to be getting the release events from SDL, but the test program didn't have the problem.
Danfun64 wrote:Do you think you can create your own git or svn repository instead of solely relying on zip files with the complete source code? It would make applying dosbox patches and then recompiling easier.
Teppic wrote:Is it possible to remove V-Sync in windowed mode somehow? I've tried a lot of different options in the config file and nothing seems to change the V-Sync for Jazz Jackrabbit. I get 60fps choppy gameplay. I also tried to add dosbox to Nvidia and turned off V-Sync there, but it doesn't make any difference.
(I assume it's V-Sync causing it?)
Yesterplay80 wrote:Which output are you using?
Teppic wrote:Yesterplay80 wrote:Which output are you using?
openglpp
I got it working in PCEm with less screen tearing than full screen DOSBox though (or much less noticeable to me at least), so I'll likely keep using that emulator for this specific game.
realnc wrote:Can I use "output = opengl" and "scaler = normal6x forced" and simply forget about it?
realnc wrote:realnc wrote:Can I use "output = opengl" and "scaler = normal6x forced" and simply forget about it?
Answering my own question: nah, it's slow as hell during fade effects. The game slows down to a crawl when using 6x with a 640x480 game.
