First post, by Stojke
Does anyone have newer, or non time locked, version installer for 3Day Organizer from 3Day Computer Labs??
I have an year 2003 2.2 version but it always quits upon start up as the the hardwired date has expired a long time ago.
125.89 KiB
Screenshot
Reply 2 of 5, by Stojke
No luck...
16.3 KiB
But I did find out about this: http://web.archive.org/web/20070123072328/htt … ycomputing.com/
Sadly everything including update package is downloadable but not the 2.5 version that is required for the update package 😒
Maybe I could search for a similar piece of software that can do these things?
Reply 3 of 5, by Jade Falcon
Rank BANNED
BANNED
Odd? Dose this app need a system that's online?
I bet you could run it in a seemless VM were the date was never past the apps time lock. Provided it's not an app that needs to be online.
I'm betting it found that you changed the date from a windows install date or file time stamp. In sure there is away around it.
Wonder what happens when you disable windows time services.
Reply 5 of 5, by Stojke
This program is already trial free, but only in last version 2.5 which I can not find anywhere.
And it seems really useful from the images.
If anyone knows of a similar program, that isn't bloated junk and is light weight, please recommend.
