AMD K6 3DMARK, aiming for stars.
Reply 140 of 555, by meljor
Hahaha......
It's the only one I don't have that I really want... Do have the g2 but not a single mvp3 board with 2mb cache!
Reply 142 of 555, by meljor
Those are pretty rare, at least in my country
Reply 143 of 555, by Skalabala
I have landed on the moon 😁 Now to get to them stars 🤣
I am using google drive for the image. Hope it is view able. Photobucket wants my money 🙁
https://drive.google.com/file/d/1z0qOFEB0fXG3 … iew?usp=sharing
Reply 144 of 555, by appiah4
meljor wrote on 2020-04-04, 16:52:
Hahaha......
I have a FIC-PA2013 with 2MB ram but I dont truat its AGP VRM; I can not find reliable ingo on whether mine would safely accomodate a Voodoo 3..
Reply 145 of 555, by meljor
Great score skala!!
Reply 146 of 555, by meljor
Pa-2013 does not have the right regulator for the v3 3000, v3 2000 is the absolute max (read it somewhere years ago). Geforce 2mx would be very safe and i would use that with v2 (sli)
Reply 147 of 555, by appiah4
meljor wrote on 2020-05-05, 07:54:
Rev 2.1 of the board has the right regulator and the most reliable information I could find by Serpent Rider on this forum is that the 2.0 boards have the same VRM as the 2.1 boards. The only potential issue is the northbridge chip which can be the AGP compatible CE revision on some 2.0 boards but not on others. 2.1 consistently has both required elements.
My board for example is a 2.0 revision but still has the necessary VRM and Northbridge so should be fime.
Reply 148 of 555, by Skalabala
appih4, I dont see a separate power phase for the AGP on that board. Maybe it is using the 3.3 rail directly from the power supply?
Those 4 cache chips has always pulled my attention 😁 4*512kb 4ns Winbond chips will be nice :p
Reply 150 of 555, by austinham
Skalabala wrote on 2020-05-04, 17:37:
No offence, but can you post a screen shot of your run with the 3dmark settings and FPS shown?
Reply 151 of 555, by Skalabala
austinham wrote on 2020-05-11, 16:08:
from HWbot https://d1ebmxcfh8bf9c.cloudfront.net/u4702/image_id_1257775.jpeg […]
from HWbot
That is a nice board 😁 I do have those cache chips but not for sale, struggled to find them :p
Reply 152 of 555, by Skalabala
Skalabala wrote on 2020-05-12, 13:41:
from HWbot
Yes I can do that, but at the moment the record machine is stripped and put away. Busy trying something with the GA5AX but its kicking my rear end real good 🤣.
I am actually planing on making a youtube video of the system and the benchmark but I would like to get it up to 5300 points before I do so.
Reply 154 of 555, by Mentat-vvo
I wonder, who've deleted my previous post.
Nevermind..
My mobile K6-III+ 400 1.6v goes 660 MHz on Gigabyte GA-5AA. Unstable, unfortunately. Maybe, 4ns cache would help)) gotta pull it from other mobo.
630Mhz is OK.
attachment%5D
    300.08 KiB
PPro250/Freeway694x/512M/Gf3Ti500/AdvGUS
2x P3Xeon900-2M/1Gb/QuadroDCC/AWE32
K6III+400@624/P5A/256Mb/GF3ti200@500
Iskra 1031 Issue 2 - i8086 PC/XT Clone from USSR
Reply 155 of 555, by Skalabala
Mentat-vvo wrote on 2020-05-13, 14:56:
I wonder, who've deleted my previous post. Nevermind.. My mobile K6-III+ 400 1.6v goes 660 MHz on Gigabyte GA-5AA. Unstable, unf […]
Nevermind..
630Mhz is OK.
Thats awesome! 😀 4ns should be more stable. But can you post into windows at 5.5x120 with cache on?
Did you try with cache off? And is your Bios up to date, CPU says 66MHz :p
BTW I see the 1Mb P Pro there 😁
My best thus far is 690MHz in windows but super unstable. But I only have air.
I would like to see a photo of your CPU, my 400ATZs are all useless. Date&Bin code 0328UPAW
Reply 156 of 555, by Mentat-vvo
Skalabala wrote on 2020-05-13, 20:52:
Did you try with cache off? And is your Bios up to date, CPU says 66MHz :pa
I have to recap my GA-5AA, since it does not boot w2k both with 105X6 and 115X5.5.
Cache on/off does not change anything. With 6x110 it can not pass POST.
Voltage settings could not add stability, 2.0-2.7v tested.
Another issue is a reboot after launch of 3DMark2k 😬 as well as test of 3D in DXdiag in DX8 mode.
Ps. The bios is the latest beta.
712.3 KiB
Reply 157 of 555, by Skalabala
Nice! Hope you get it sorted! None of my 400ATZ chips are stable at 115x5.5 Think they need LN2
I am still trying everyday to make ATI card work fast with ALi chipset. I keep on failing 🙁
What graphics card and drivers did you use? ATi card with me is slow or just restart PC when launching D3D app 🙁
Reply 158 of 555, by 65C02
from HWbot
I don't get it! How do you guys get such high scores? This is better than my Celeron 800MHZ with NVIDIA Ti4200 = 3469 pts. I also saw someone else getting more than 12000 with a P3 which I think my score should be closer to. Is it because I run Windows ME? Should I try 98 or XP instead?
Reply 159 of 555, by appiah4
65C02 wrote on 2020-05-15, 01:40:
from HWbot
Sounds like you are on a VIA board without VIA 4-in-1 drivers so your AGP is running in PCI mode or something..
