First post, by PhilsComputerLab
- Hardware Mod
In this project we are using a Windows tablet, USB MIDI interface and Falcosoft's awesome MIDI Player to build the Ultimate MIDI Emulator!
Falcosoft's MIDI Player: Falcosoft Soundfont Midi Player + Munt VSTi + BassMidi VSTi
I mucked around with Raspberry Pi a little bit, but found it way to clunky and complicated and once you factor in all the accessories, a cheap tablet doesn't cost that much more 😀
The idea behind this is to make MIDI DOS gaming more accessible seeing how expensive some of these modules are. With this project you can emulate:
- MT-32 (Old)
- CM-32L
- Sound Canvas (SC VA needs to be purchased unfortunately)
- Yamaha SoftSynth
- ANY SF3 SoundFont (Spoilt for choice)
I created shortcuts to launch each config, so it's super easy to use.
