Are GeForce 256 DDR cards that rare?
Reply 240 of 318, by appiah4
T&L seems to be a boon for builders like me, who usually cut down on costs by going for budget CPUs paired with fancy GPUs at the time. I had a Voodoo 3 running on a PII-350 for example - that thing scales up as high as PIII 800 IIRC. Most of my current retrobuilds still reflect that mentality (PMMX and Voodoo 2 SLI etc..). I plan on replacing my Voodoo 3 in a PIII 450 system with a GF256 DDR + Voodoo2 SLI at some point. I'm fairly sure T&L will help there.
Reply 241 of 318, by Scali
silikone wrote:
Is the application of eight lights not largely variable? Local lights should be more demanding than directional sources, and the amount of geometry being affected by each light is also to be considered.
The 3D Mark test seems to simulate the worst case scenario, with the maximum number of hardware lights all present locally, blending together on a high-poly mesh. I'd imagine that in more practical usage, eight lights would be feasible on this period of hardware with excellent results.
Well, that's the point. I believe it has a 1M poly scene, which was considered extremely high-poly at the time. The sole purpose is to test the T&L performance of the GPU (or CPU in case of software T&L, although by 2001 hardware T&L was commonplace).
I don't think any games actually used anywhere near 8 lights.
But sure, you could think of situations with low enough polycount (and remember that there's attenuation/cutoff for the lights as well, so the lights can be culled altogether on polys that are far away, especially if you use high attenuation factors) that 8 lights are feasible in realtime.
In fact, the high-end GPUs of the time (think GF3/GF4/Radeon 8500) didn't even do all that badly in this test.
In 3DMark2000 there is a similar high poly test by the way, but less heavy, more tailored to first-gen T&L hardware perhaps.
Reply 242 of 318, by The Serpent Rider
Meanwhile mysterious Eagles GeForce 256 32mb is on the way.
Reply 244 of 318, by The Serpent Rider
Look for it by memory size and type filters. But it's easier to find GeForce 256 on local markets for cheap price.
Reply 246 of 318, by dexvx
Yea... I've been looking every since I posted this question. I've seen one NV10 SDR locally at the recycler.
My eBay seller (for NV10 DDR) seems to have inventory problems, still not shipped out. Not a good sign.
Reply 249 of 318, by The Serpent Rider
My abomination has arrived.
1.32 MiB
1.19 MiB
Surprisingly enough that's 128-bit card with just slightly underclocked memory - 120 mhz chip/150 mhz memory. Despite its ugly duckling appearance I've successfully overclocked it up to 150/195 mhz. VGA quality is blurry though and fan is completely dead.
Reply 250 of 318, by agent_x007
Can that FAN be moved manually ?
Because it may need a simple oil drop in bearing + a lot of manual pushing 😀
Ugly suck is a lot faster than my card 🙁
On the other hand, I own the only 64-bit SDR GF256 around here, aren't I ?
Reply 251 of 318, by The Serpent Rider
It moves but oil did nothing unfortunately. Looks like heat from GPU just killed the rotor.
I'm quite sure it's not really problematic to find that ASUS abomination. Sooner or later I'll stumble upon it.
Eagles card looks very similar to this 64-bit model though: https://www.techpowerup.com/gpudb/731/geforce-256-sdr
Reply 252 of 318, by dexvx
I posted this in the general forum, but I'll post it here as well I guess. Visiontek GeForce 256 DDR 32MB. Stock at 120/150. Memory is -6, so it should go to 166 no problem. Fan is dying.
Still on the lookout for my old Creative Labs Annihilator Pro.
Reply 253 of 318, by Reputator
I'm fairly certain the DDR cards were only 150MHz on the memory. Unless you want it to go to 166 for a different reason.
http://www.anandtech.com/show/429/2
https://www.youtube.com/c/PixelPipes
Graphics Card Database
Reply 254 of 318, by TheAbandonwareGuy
Am I the only one here with an ELSA Erazor X SDR?
Reply 255 of 318, by s0ren
A guy near by had an IBM Aptiva PIII-700/133 for sale with a TNT2 M64 card, which i picked up for about 60$. Not a particularly good price, but old hardware is rare around here.
When i came home with it, i found that the graphics card was a CT6970 Creative Annihilator and not another shitty M64 😀 (picture attached) Exactly the card i wanted for this machine, so this saves me a lot of eBay browsing.
    2.65 MiB
Reply 256 of 318, by appiah4
That actually is the Annihilator Pro with the DDR memory I believe.
Reply 257 of 318, by Fusion
I bought a M64 off a guy for 10 bucks and a SB16 for 10 as well and when I tested the M64 it turned out to be a TNT2 Pro. W00t.
Pentium III @ 1.28Ghz - Intel SE440xBX-2 - 384MB PC100 - ATi Radeon DDR 64MB @ 200/186 - SB Live! 5.1 - Windows ME
Reply 258 of 318, by TheAbandonwareGuy
TNT2 Pro is rare now?
I payed like $10 for mine which has DVI instead of VGA which I assume makes it more rare than regular pros. A 32MB Pro is basically an Ultra -10MHZ. Add that 10MHZ back and they should in theory be the exact same.
Ultra's aren't even that hard to find if you know what to look for. I paid $14 for mine (a Gateway OEM)
