First post, by fitzpatr
- Member
Hello, everyone,
I'm in Tokyo at the moment and I came across a Roland SC-D70 in my search for MIDI modules. (Sadly, the only one that I have been able to find.)
Does anyone have experience using this module? Specifically, I'm wondering how it compares to the SC-55mkII (which I have) and the SC-88Pro (which I want).
I intend to use it for GM/GS compatible games.
The only references to it that I can find are from skyscraper in a couple of older threads.
From what I can tell, it seems to be similar to the SC-8820/8850 series, and it includes a S/PDIF output.
Thank you!
MT-32 Old, CM-32L, CM-500, SC-55mkII, SC-88Pro, SC-D70, FB-01, MU2000EX
K6-III+/450/GA-5AX/G400 Max/Voodoo2 SLI/CT1750/MPU-401AT/Audigy 2ZS
486 Build
