https://www.youtube.com/watch?v=zlJ0j3t0rN8&t=36s
milepanic wrote:Playing Moded TR3 using Peixoto patch, with custom HD textures and up-scaled and enhanced FMV videos (made by me)
Peixoto wrote:milepanic wrote:Playing Moded TR3 using Peixoto patch, with custom HD textures and up-scaled and enhanced FMV videos (made by me)
Awesome, post the video here:
http://www.tombraiderforums.com/forumdisplay.php?f=8
people are sure to like it
tezinho wrote:Peixoto wrote:tezinho wrote: Windows 10 x64 the game works perfectly without problems with MP4 or in-game sound.
Problem solved !!
Anyway, try to re-encode the mp4 files as bnik. For the sound, run setup and select you instead of selecting "primary sound driver" select the other option that appears. Also try to remove the singlecore=1 option from tomb2.ini
W10 on this laptop is slowww, but if it is necessary will be the way. I'll try these tips, thank you very much.
Hello, me again
Problem solved 2x![]()
I found the problem on my W7 x64.
First I started to suspect the LAV decoders filters and in my case I discovered a setup in the K-Lite Codec.
After installing the K-Lite Codec... i opened 'Codec Tweak Tool' and worked on the 'Preferred decoders' option in the Win7DSFilterTweaker section.
Inside there is a setting for "H.264", default option is "USE MERIT", here I changed it to "LAV Video" and the TR2 MP4 videos worked without problems in my W7 x64.
On W10 x64 I did not need to change this parameter.
Time to play again after 20 years.
milepanic wrote:Quick question about resident evil 2, is there anyway to stretch game so i dont see those black bars on the side, and is anyone have maybe upresed textures of environment that i can replace in game? I'm using Resident Evil 2 sourcenext version. Thanks!
Peixoto wrote:milepanic wrote:Quick question about resident evil 2, is there anyway to stretch game so i dont see those black bars on the side, and is anyone have maybe upresed textures of environment that i can replace in game? I'm using Resident Evil 2 sourcenext version. Thanks!
That would make Ada look short and fat. Think about it !
catfromnesbox wrote:trying to play onimusha with your patch and i got this
animal1989 wrote:Can I get a vac ban on steam from this patch?
klappa wrote:My AV warned me that the help file contained malware. Why is that?
habla2k wrote:Hey Peixoto,
great work with your fixes for RE2, just enjoyed two playthroughs after almost 20 years. Now, since i never played RE3, i was wondering, if you have something similar for Nemesis, especially your clean character models would be so nice to have.
Anything like that possible for RE3?
Peixoto wrote:klappa wrote:My AV warned me that the help file contained malware. Why is that?
Doesn't RE3 already supports hight resolutions ?
habla2k wrote:Peixoto wrote:klappa wrote:My AV warned me that the help file contained malware. Why is that?
Thanks for answering. It does have higher Resolution, but not until FHD, besides, with your patches the 3D models were a lot cleaner and with higher detail.
Hello there. Windows 10 Home 64, GeForce GTX-670, Ryzen 1700.Xpresso wrote:when I want to run any Tomb Raider I get Unable to find or load C/: Users/... /Peixoto/peixoto.dll-126
Return to Release Announcements
