About removing and replacing barrel batteries..
Reply 100 of 112, by Jo22
Before it dies, I would like to say that a diode can also safe the motherboard.
If the battery shorts internally due to what ever reason, a small glass diode (1N4148 or similar) can prevent a short circuit.
Because, in the unlikely case the battery is shorted, and the diode successfully prevents the PSU from charging the battery, the diode acts as a fuse.
It's not a proper fuse by any means, but it's a weak part that can fail under such circumstances (good thing).
Edit: Small edit.
Reply 101 of 112, by mrwho
Good evening all.
I have almost no knowledge of electronics whatsoever, so could please someone explain to me in simple terms how to use a multimeter to check if an external battery connector is charging the battery?
I already bought some double cr2032 sockets with batteries and I'd like to confirm it's safe to use them with the external connection.
Thanks!
“Hey, you sass that hoopy MrWho? There's a frood who really knows where his towel is."
My home retro drivers repository: ftp://retro:drivers@mrwho.duckdns.org
Reply 102 of 112, by chrismeyer6
Set your meter to the DC voltage setting and then take the two probes and put the red probe on the positive (+) pin of the battery connector and then place the black probe on the negative (-) connector on the ext battery connector. If you have voltage present then it's designed to charge an external battery. If no voltage is present then your all set. If voltage is present you'll need a blocking diode inline with your new battery to prevent it from charging and causing problems.
Reply 103 of 112, by mrwho
chrismeyer6 wrote on 2021-06-16, 22:43:
Thank you, that seems simple enough - from a previous post I was under the impression that I needed to measure amps with the battery present.
About the diode, if needed, do I place it between the + connector and the battery? And what about the diode polarity? And what kind of diode?
Thanks again.
Reply 104 of 112, by chrismeyer6
You can put the diode on the positive side and you want it so it let's power flow out of the battery to the motherboard. They usually have an arrow that shows it's directionally and you'd want it facing the motherboard so it blocks power flowing into the battery. You just need a blocking style diode nothing special or fancy.
Reply 105 of 112, by maxtherabbit
I have never seen an external header for a rechargeable in any type of clone system. Perhaps there were some OEM builds that worked this way, but it's not a common thing by any means
Reply 107 of 112, by Dusko
Chrismeyer6, I posted a diagram in this thread How to modyfy SOYO SY-4SAW2 to take Lithium Cell, instead of Nickel rechargeable. Bios upgrading.
It should be the case for many motherboards as I was able to validate.
Maxtherabbit, I have a few motherboards that are not OEM that have headers for external batteries. I have attached CR2032 batteries and they still work so I guess they don't have the recharging function in the headers.
https://www.youtube.com/@myoldpc9458
Reply 108 of 112, by Dusko
The motherboard should have a circuit like the one below, you just need to look at the components near the battery and take some continuity measurements to figure it out. You need to cut the line somewhere between the yellow mark, either by removing the diode, the resistor or just cutting the trace anywhere between them. The +5v line comes directly from the +5v pins of the power connector so it's easy to find.
    36.88 KiB
Reply 109 of 112, by MotoPete
pixel_workbench wrote on 2021-06-10, 13:58:
That's a terrible idea. You can learn about the details of different batteries here: […]
tonata wrote on 2021-06-10, 08:02:
Can you please comment on my solution on using a 18650 lithium ion rechargeable battery. Can these batteries be safely recharged by a 386 motherboard while in use?
Here is a 18650 https://fr.aliexpress.com/item/1005002420574151.html charger if a comparison can be made. Or maybe I should put a diode to be on the safe side reducing to it 3.3 V ?
https://batteryuniversity.com/learn/article/c … based_batteries
https://batteryuniversity.com/learn/article/c … m_ion_batteries
It's a pity these links no longer work as I'm sure they were an interesting read.
I use a LIR2032 in a button cell holder soldered directly to the motherboard in place of the OEM unit. Saves all the mucking about. Never had an issue.
Reply 110 of 112, by maxtherabbit
Dusko wrote on 2021-06-27, 02:37:
So we are saying the same thing. I was saying the headers do not recharge, not that they do not exist
Reply 111 of 112, by Dusko
maxtherabbit wrote on 2021-06-27, 15:07:
Right! I misread your message, sorry.
Reply 112 of 112, by pixel_workbench
MotoPete wrote on 2021-06-27, 03:57:
Strange. You can go to the main site and navigate to the articles, if the direct links are not working. Worth a read.
My Videos | Website
P2 400 unlocked / Asus P3B-F / Voodoo3 3k / MX300 + YMF718
