First post, by Pabloz
Today i bought a case just because it had a turbo button and display. really cheap.
The seller told me it had the chip inside and that the pc worked, i told him i just bought it because of the case, and when i opened the case i saw motherboard+cpu+trident+IO card+ PSU
motherboard has 2 cpu slots, only 1 intalled cpu 486 dx
Does anyone know what model/brand it is? there almost zero jumpers in this board, so i don´t know if it can be upgraded to a DX2 or DX4?
Reply 1 of 19, by 386_junkie
Nice board, though I didn't realise Morse did boards beyond 286/386. I have seen Morse for 386 but not thought much of it.
That second socket is for a Weitek 4167, a form of FPU that maps memory differently than typical FPU's and are generally only used in RISC applications and lower level programming i.e. Unix and C etc.
Reply 2 of 19, by Pabloz
Indeed it is very nice, it had so much dust that i had to take out a paint brush and now looks like brand new. I like it a lot. The battery is kind of green on one side, might have to be replaced. but i don´t know the model number of the board. I really doubt i can upgrade it to a DX2 cpu 🙁
Reply 3 of 19, by 386_junkie
I can't see the battery (off the page!) but I would take it off straight away... it'll eat the board alive and may cause permanent damage.
I don't see why a DX2 can't be used... both DX and DX2's are 5v CPU's... it should not be a problem.
A DX4 will not be possible however as this CPU runs off 3.3v. If you have an adapter to step down the voltage from 5v to 3.3v then it will be possible... but then you would ask if this is worthwhile on an ISA only board.
Reply 4 of 19, by Pabloz
fount it!
MORSE P1
http://stason.org/TULARC/pc/motherboards/M/MO … INC-486-P1.html
can do
Processor
80486SX/80487SX/80486DX
Processor Speed
16/20/25/33MHz
ah well its nice extra to have, i wanted the case anyway. 😀
Reply 5 of 19, by 386_junkie
Sometimes the jumper configs online are not always correct or complete... it would not surprise me if the board did actually run with a DX2.
What case?... Did you post a picture?
Reply 6 of 19, by cyclone3d
The DX2 chips just run double the speed of the FSB.
They should work fine no problem I would think.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 7 of 19, by Pabloz
wow you just made me want to buy a dx2 chip to see if it works or not on this board.
the case is nothing fancy , i actually paid 2 dollars for everything
plastic turned yellowish, but i know that if you buy hydrogen peroxide (H202) solution and OxiClean. and leave it at the sun the white comes back
Reply 8 of 19, by davidmorom
Hi, Pabloz! Do you still have that board? I found exactly the same board, but the BIOS chip is empty. I tried several BIOS for 486 I found around there, some of them works, but neither of them are capable of using SRAM cache, so it is very slow. Can you dump the BIOS chip and share it with me? Thank you!
Reply 9 of 19, by dionb
If Pabloz can't I might be able to. I found 8 of these NOS, 7 of which worked (the battery juice demon had gotten the 8th); sold most, but still have one.
I'll see if I have time to read the BIOS this evening.
Reply 10 of 19, by davidmorom
That would be great! Thanks a lot.
Reply 12 of 19, by davidmorom
dionb wrote:
Back to live again! One more board for the retro-computing colletion. Thanks for your help.
    166.92 KiB
Reply 13 of 19, by dionb
davidmorom wrote:
Great!
Out of interest: how did you confirm that the cache was working?
I just checked mine and it claimed cache was enabled, doesn't give any POST errors for bad cache - but cachechk doesn't find any (L1 or L2), and speedsys shows very poor results, indicating that cachechk is right about it not working...
I have 256kB 25ns Mosel SRAM L2 - and I've tried everything from the original, supported i486DX-33 (8k L1) to an AMD 5x86-PR75 (133MHz with 16k L1 - via a voltage interposer), but absolutely nothing gets cached.
Reply 14 of 19, by dkarguth
You wouldn't still happen to have the dead board, would you? I do board level trace repair, and am always looking for dead boards to revive!
"And remember, this fix is only temporary, unless it works." -Red Green
Reply 15 of 19, by dionb
That's a special kind of masochism. I think I still have it. Doesn't look too bad, but as soon as you power it on, it blows a tantalum cap. Replace the cap and it blows it straight again... if it's worth transatlantic shipping to you (EUR 24) you're welcome to it, and I can chuck in at least one more (386) board with bad battery damage too. PM me 😀
Reply 16 of 19, by davidmorom
dionb wrote:
Great! […]
davidmorom wrote:
Great!
Well, I don't really know if cache is working, I assumed it is just because POST prints the following:
Internal (486) cache controller enabled
External cache controller enabled
External cache size 256KB
With other BIOS images I tried before, POST just said Cache: 0KB. And everything was REALLY, REALLY slow. For example, in the BIOS setup, I could see the characters appearing on the screen almost one by one. But maybe this is not related with cache, and it is another side-effect of using the wrong BIOS.
Next week I'll do some deeper testing, to see if I can figure out something. One guess: maybe the turbo header has something to do in the behaviour of the cache? With it shorted is much faster than with it opened. Maybe this board disables cache when the trubo header is open?
Reply 17 of 19, by quicknick
If dkarguth doesn't take advantage of your offer, I'm jumping right in. Same kind of masochism, I guess 😁
Reply 18 of 19, by davidmorom
I just did some benchmarking, and it seems cache is working and performance is the expected for this processor. Cachechk only detects 256KB of L2 cache, but speedsys detects both of them, 8KB of L1 and 256KB of L2. The CPU benchmark result is between a 386DX at 40MHz and a 486DX2 at 50MHz, which I think is just correct for a 486DX at 33MHz.
I attach some captures of the results.
    157.67 KiB
    177.29 KiB
Reply 19 of 19, by Deunan
Check if you have BIOS setting for internal cache. Could be it's set to disabled, while at the same time external cache is enabled. Speedsys might be enabling L1 on it's own during the test.
