First post, by cj_reha
- Oldbie
I am building a 3dfx voodoo 2 build with a FIC PA-2007 motherboard and it's not playing well with my mice.
I first tried connecting the serial ribbon to the COM1 and 2 ports on board, trying all IRQs, and it either did not find it or found it, and detected the mouse, but the cursor could not move and you couldn't click.
I bought a Lava Computers ISA serial port card, set the jumpers accordingly and the board detects the two ports fine as com1 and com2. It even finds them in 98se, and finds the mouse. All of the on board i/o ports are disabled, btw. However it does the same thing as before, cursor cannot move and you cannot click anything.
The mouse is a standard Microsoft serial mouse that works fine with the 10 other pcs of various ages I have used it with, so I'm not sure what the problem is here.
