cxm717 wrote:Hello. I really like your OR840 setup!
Thanks!
cxm717 wrote:I have an OR840 board and was planning on getting a pair of P3/S CPUs running in it. I ordered some pre modded P3/S CPUs on ebay and I already have a few MSI slocket adapters (6905 ver2). Hopefully it works.
I'm fairly sure it won't work right away. My guess is you ordered the korean modded CPUs from ebay? If that's the case the mod will need some work.
This is my "reverse engineering" of that mod, done a while back in this same thread. To get it to work there are at least 3 things to do;
- For starters, on the right between a yellow and red line there is a resistor marked "150" with the label "NCH". You need to remove that and bridge those 2 contacts with solder.
- Right on top of it there are yellow and black lines, with the label "RTT". You need to add a 110 Ohm resistor there. (Can be added to the slotket instead.)
- Finally, around the bottom there is another pair of yellow and black lines labeled "SLEW". Another 110 Ohm resistor is needed there. (Can be added to the slotket instead)
Besides that, on the left you'll see a resistor marked "151" between red and marroon lines. This is 150 Ohms, my mod uses 680 Ohm, and the intel datasheet recommends 1 kOhm. And finally, on top between red and blue lines there is a resistor with the marking "102", this is a 1 kOhm resistor that I don't use and don't know if it will interfere with anything when using the mod in the OR840.
Of course, once you get the components feel free to post here again and we can try to get you up and running!
cxm717 wrote:I have been looking for an updated BIOS for this board without any luck, can you share the updated BIOS or give me a link to where you got it?
Here you go, the latest BIOS files for the Intel board and the IBM board
- Filename
- or840_intellistation.zip
- File size
- 1.05 MiB
- Downloads
- 124 downloads
- File license
- Fair use/fair dealing exception
- Filename
- or840_bios255.zip
- File size
- 784.33 KiB
- Downloads
- 121 downloads
- File license
Note that for the intel board you WILL need either a floppy drive or a Gotek to flash. I consider myself fairly resourceful and couldn't flash the BIOS any other way. The intellistation BIOS has a couple of readmes inside the file when you extract it, one of which describes how to add new microcodes to the BIOS, so if you locate Tualatin microcodes you can add them hassle free.
cxm717 wrote:I'm also interested in your aux power connector mod. Is the aux connector needed on this board? I noticed that some older dual CPU boards use it (I have a few IBM intellistation M pros that use the aux connector)
The board will run without it, but I recommend you use it if you run a dual setup. Its basically an early version of the 24pin ATX connector, using that 6pin AUX header instead. I had a PSU with the 6pin connector, but after it failed spectacularly I switched to a new, modular PSU. I just cut the 6pin connector from the old PSU, figured out the position of Ground, 5 V, and 3.3 V in the modular PSU outputs, and soldered a wire together. Since the pinouts of modular PSUs are not standardized, I can't really help you beyond that.
Good luck with the board!
Outrigger: an ongoing adventure with the OR840
QuForce FX 5800: turn your Quadro into a GeForce
