Reply 20 of 39, by Tetrium
WELCOME BACK RG100! WOOOOO!!!!! 😁
Now on to business, chances are I actually have the paper manual hidden somewhere! I know I got 2 manuals of 2 different versions of this ISA controller, I will see if I can look them up. Hopefully they will be of the exact same card as yours.
edit: I actually do have the paper manual of the IDE PLUS-V3L-002 🤣!
I'll take a couple pics and upload them here, just give me a minute 😜
edit2:I'll just dump the pics here. Feel free to ask any questions, but the "manuals" were basically nothing more then small sheets of paper 😜
Argh...just noticed I forgot to take pics of the back side 🤣. Will add these in a minute as well 😜
    444.11 KiB
    348.1 KiB
    417.33 KiB
    424.51 KiB
    415.92 KiB
My retro rigs (old topic)
Report spammers here!
Reply 21 of 39, by Tetrium
Backside:
896.34 KiB
912.2 KiB
861.25 KiB
The other 2 manuals are for the IDE PLUS-V4L and the IDE PLUS-V2 004, if anyone wants then, perhaps I should make some proper scans of them?
Hope this helps! 😀
Reply 22 of 39, by Tetrium
Anda ofcourse I fell for the necro thingy 🤣!
But still nice to have these manuals online somewhere 😀
Reply 23 of 39, by nest_and_art
Another Prime-2 Card from "Gear" (?)- But with "Game" connector
    709.24 KiB
Reply 24 of 39, by Robin4
jesolo wrote:
I have a similar one with the Goldstar (LGS) Prime 3B chipset. […]
This is an 8-bit card, with only a floppy connector and ASYN connectors, but I've been unable the find the jumper settings for this one.
Nice card to use in an XT.
Never seen such controller card in a 8 bit version..
Reply 25 of 39, by .legaCy
konc wrote:
Another common use for a serial port was modems, so it made perfect sense to have more that one.
A CDROM should work on this IDE connector, but I HAVE come across similar controllers not working with ATAPI drives. So the answer is most probably yes, but it's not certain without confirming it in practice of from the manual.
i have one vlb card if im not mistaken is a goldstar prime 2c vlb, it was finicky with cd-rom being the master on the secondary ide channel, or even being slave, it only worked when i used it on the same channel as the hdd but as slave.
And it also didn't worked with every cdrom drive, i had to test 3 drives that i had laying around.
Useful links
[ How to Multiboot any OS | Rebuilding GOG Installer for Win9x | 486DX-4 Build | S7 Time machine Build |
twitch stream (in portuguese)
Reply 27 of 39, by yawetaG
On the retronn link (http://retronn.de/imports/hwgal/hw_goldstar_prime2.html) there is shown a card AIO-200G-V3.00.
If someone has the manual for that one and/or knows the jumper settings, I'd be very grateful. It is the mystery I/O card I bought in April of this year, and I want to know whether it's possible to enable the game port only, to add a game/MIDI port to a system with integrated SB sound but no game port.
Reply 28 of 39, by Tetrium
retro games 100 wrote:
Tetrium, thanks very much for uploading the manual. That was really good of you to do that. I'm sorry for the late thank you too!
You are welcome 😀
And no worries, I'm just glad it helped 😀
Reply 30 of 39, by Tiido
These chips only give base hardware and require no special drivers. Windows will see the IDE, floppy, COM, LPT and gameport without problems.
And I very much appreciate the scans of the manual earlier in this thread ~
Reply 32 of 39, by Tiido
Such a motherboard has an onboard SuperIO chip and all accesses to things like Floppy, COM and LPT get forwarded to that instead of ISA device. There's likely onboard PCI IDE and any access to the (primary) IDE goes straight to that and not to ISA bus. So end result is such a card isn't useful on a motherboard like that.
Reply 33 of 39, by Tatarus35
Tetrium, sorry for asking after almost two years, but could you please somehow upload that IDE PLUS-V2 004 manual? I just bought working 386 DX-40 mainboard, and the i/o card that came with it is exactly the IDE PLUS-V2 004 with Acer chip. It'd would be VERY helpful for me to have the user manual, since I have little to no experience in setting up such an old hardware.
Anyway, thank you for that posts and best regards!
Reply 34 of 39, by Tetrium
I'm not sure if I have it, though I do remember that I had several of those paper manuals.
The only issue is that I currently don't know where these manuals are. I've been busy with a kinda a large project and I've been moving a lot of stuff around and a lot of stuff is now packed up.
So unless I happen to bump into it by sheer luck, it may take a while before you're no longer out of luck.
I'd take it you haven't been able to locate the manual elsewhere?
Reply 36 of 39, by Tiido
That is a limitation of the BIOS of your motherboard and not the IO card and its chipset.
Reply 37 of 39, by RiP
Thanks again, anyway to check the limitation of the BIOS by a software?
It's Sega Teradrive (286 CPU) 😎
Reply 38 of 39, by Tiido
It is probably 504MBytes, if you can set CHS settings manually, otherwise it is whatever predefined settings the BIOS lets you use and those are rarely above 40MB on such old machines.
Reply 39 of 39, by tomdearden
Hi - I've got this exact card and came across the following which seems to work perfectly with the 004 version:
https://stason.org/TULARC/pc/hard-disk-floppy … s-IDE-PLUS.html
Hope it's useful!
