Reply 40 of 455, by Scali
Very nice work!
As for redirecting C0h to 2C0h... we had a discussion on that earlier with the Lo-Tech card, and the solution we came up with was to patch the 'out c0h' instructions in code to 'int c0h'.
Then a very simple TSR would hook into int c0h, and send to the desired port. The big advantage is that it doesn't require a 386+.
I believe there was a collection of game patches for this somewhere, by Carlostex.
Reply 41 of 455, by pdw
Well, here's a quick TSR: http://github.com/pdewacht/lotech
Obviously untested. Should work with QEMM.
(EMM386 doesn't allow intercepting port 0C0h. With EMM386 it still listens on a few other ports for later Tandy's and IBM PS/1, but that's of very limited usefulness.)
Reply 42 of 455, by matze79
Wow thats really fast, Thanks ::)
its freezing after loading with a blinking "_".
i will do my best to quickly supply you and dreamblaster with a prototyp card 😀
The static const int qemm_ports[] defines the ports intercepted right ?
i could try to remove some and recompile the tsr.
outp sends to 0x205 ? (Silence Code)
what is 0x205 ? a realport or is it a handler ?
Reply 43 of 455, by Scali
Port 205h is what the IBM PS/1 audio adapter card (also based on SN76489): http://nerdlypleasures.blogspot.com/2015/10/t … sound-chip.html
Reply 44 of 455, by pdw
I see the bug, 0x2C0 should be removed from the qemm_ports list. I'll make a new build tonight.
The 0x205 thing is a remnant of the TNDLPT code. As Scali said, 0x205 is the port that was used by the IBM PS/1 sound card. It gets trapped and emulated just like port 0xC0. Doing the silencing that way was easier than making it possible to call the TNDLPT output routine from C 😀
Reply 45 of 455, by matze79
I'm installing currently open watcom 1.9, takes some time on a 486DX2 50Mhz 😀
i can change it quickly and retest.
i also saw it, but was not sure about.
Reply 46 of 455, by matze79
77.61 KiB
TSR works, i patched the line.
vgmplay test1.vgm 0c0 works fine with card listen to 2c0 😀
this tsr could be useful for tandy owners too (386 machines)
76.4 KiB
Reply 47 of 455, by matze79
i tested the tsr on at least 3 machines and it works fine.
anyone got prince of persia running with the lotech tandy card ? commandline parameters are not accepted.
Reply 48 of 455, by Scali
Do you have an AdLib or compatible card installed in the machine?
I recall there was an issue with the autodetection in Prince of Persia, where it would always use an AdLib if present, regardless of commandline parameters. There is a patch for that issue somewhere. The issue is also mentioned here: http://nerdlypleasures.blogspot.com/2015/08/p … sound-card.html
Reply 49 of 455, by matze79
only pcspeaker and sn76489 (486 system).
ok i will try that, but i tried about a year ago and it did not work for me.
Reply 50 of 455, by Scali
I only tested with my GameBlaster clone, and had similar issues.
I have the Tandy clone in the same system, so I will give it a try tonight.
Reply 51 of 455, by Scali
Yea, just tested it... the regular version 1.0 doesn't work... gives PC speaker, even when you specify 'tandy' on the commandline.
The patched version I made works fine with the Tandy clone card.
Reply 52 of 455, by matze79
i patched prince 1.0 and still have only pcspeaker sound with port interception tsr (2c0h), no sound with card listen to 0c0h, maybe there a differences in 1.0 versions ?
did this - at Offset 13875h changed 75h to EBh,
"prince tandy" gives me no sound at all.., running with port interception tsr it starts with pcspeaker sound.
stunts, eye of beholder, civilisation, maniac manison and so on works.
dune 2 does not work, simant does not work, no sound, alleycat with bjt patch, also does not give me tandy sound.
could this be a issue because i run on at machine ?
Can you try one of these games ?
Dungeon Master also is not working, because of auto detection, still have no clue how to patch this 😀
already did some disasembling but i have no clue howto find the the coresponding part in the binary file to set auto detection to all true.
Reply 53 of 455, by Great Hierophant
Does your program intercept a memory read to the BIOS at FC00:0000? Most games use the Tandy identifier byte there (21h) to determine whether to use Tandy sound, and to a lesser extent, Tandy graphics.
Reply 55 of 455, by matze79
if some one wants a prototyp pcb just pm me, i take only production cost ~4€ and shipping.
i can post a BOM and Hex file for the Attiny13, if you have no ISP Programmer you just can hook it up to a raspi or your computers lpt port to program it.
EDIT: BOM corrected. C9 = 220uf, 47nf should be 47uf.
ERRATA of Prototype Card:
R11 left side must connected to variable resistor.
Connect it directly to the Pin thereunder.
    tandy_sound-1.txt
    6.76 KiB
    106 downloads
    tiny13.7z
    434 Bytes
    115 downloads
    MCU Firmware
    Tandy SN76489 Prototype bracklet(1).7z
    52.76 KiB
    87 downloads
    3D Printed bracklet
Reply 56 of 455, by matze79
1.53 MiB
1.54 MiB
Some Impressions 😀 Slot bracklets are currently printing.
Now with ENIG.
Thanks Dreamblaster for all help! 😀
50.57 KiB
Reply 57 of 455, by root42
Awesome! My SN76489AN are supposedly on their way. Will soon also be able to assemble the prototypes you sent me!
YouTube and Bonus
Reply 58 of 455, by matze79
Is Anyone are intressed into a building Kit or a fully assembled Card ?
Maybe i will make a limited amount of kits.
