Reply 60 of 455, by Beegle
matze79 wrote:
Is Anyone are intressed into a building Kit or a fully assembled Card ?
Building kit would be awesome!
The more sound cards, the better.
AdLib documentary : Official Thread
Youtube Channel : The Sound Card Database
Reply 61 of 455, by keropi
how much a kit shipped in DE would be?
the cards look ace 😎
Reply 62 of 455, by j^aws
Maybe i will make a limited amount of kits.
These cards look really nice. I would be interested in a fully assembled card. Please let me know when you are ready to prepare one. Thanks for the offer.
Reply 63 of 455, by gdjacobs
Based on sentence structure, I suspect your business trip has you thinking in German? 🤣
Reply 64 of 455, by matze79
around 35€ ~ i don't have made excact calculations until now.
i have a few of the last batch avaible (ready cards), which i can give away.
The difference between the building kit version will be minor 😀
just some small adjustments.
Reply 65 of 455, by root42
In a few weeks I will also have two cards. One will stay with me. If the second works as well, I will create a little giveaway contest. 😀
YouTube and Bonus
Reply 66 of 455, by carlostex
matze79 wrote:
around 35€ ~ i don't have made excact calculations until now. […]
That's a fair price. I can't buy one right now but i'll definitely want one in the future. I think i have spare SN76489 chips laying around in my parts bin.
Reply 68 of 455, by matze79
i started working on a small program, for muting channels.
its annonying to have 3 com files, each for for a address.
its working 😀
93.27 KiB
Here is new MS-DOS Utility: http://www.retroianer.de/SNDOFF.EXE
Reply 69 of 455, by matze79
Here is Code for Linux:
http://www.retroianer.de/sn76489.c
compile with -O2 or -O..
Noise in video is just because i removed MCU for testing purposes.
    linux test video.7z
    594.2 KiB
    64 downloads
Reply 70 of 455, by matze79
Don't connect PC-Speaker Input wrong, + is on the edge of the card.
PC-Speaker Mix In does not work on more modern Boards.
Seems they are optimized to drive Piezo Speaker.
(Using 2 Driving Pins..)
For example my Super7 - K6-2 (Commate A7SX).
Reply 71 of 455, by SteveC
Love things like this project - well done 😀
Reply 72 of 455, by matze79
there is still some work todo 😀
Thanks!
Dreamblaster also helped me a lot, he send me many parts so i could build prototypes 😀
Maybe in few months you will find the Final Tandy SN76489 Card at the Serdaco Shop and can enjoy a lot of Patched Games and also native ones.
Fratzengeballer from dosreloaded.de forum will also help, patching more Games 😀
And Thanks to pdw for working on the TSR for more modern Computers.
This community is amazing.
If everyone works together we can move mountains.
Reply 73 of 455, by root42
I finally got around to soldering the two prototype boards you sent me. All went well, except for two things:
1. I can't flash the attiny13. Verification step always fails. Using an usbasp clone with avrdude. Any ideas here what to do? Got the pullup between reset and Vcc, but it doesn't help.
2. The BOM said 47uF on C8. However the LM386 datasheet says there should be a 0.05uF there, so rather 47nF...?
Hope to get some answers. Can't wait to try out the card!
384.15 KiB
825.95 KiB
YouTube and Bonus
Reply 74 of 455, by matze79
root42 wrote:
I finally got around to soldering the two prototype boards you sent me. All went well, except for two things: […]
Hi,
this is right, C8 is 47nf yes. (Errata in BOM)
It seems you have ATTIny13A choose the right MCU 😀 Tiny13 and Tiny13A differs.
Reply 75 of 455, by root42
Ok, will find some 47nF ones.
Concerning the ATTINY: I have this one:
https://www.mouser.de/ProductDetail/Mic ... KtbA%3d%3d
Doesn't look like the A variant...? I will try avrdude with 13A anyway.
YouTube and Bonus
Reply 76 of 455, by matze79
can you post the output of avrdude ?
Kannst du die Ausgabe von avrdude posten ?
Reply 77 of 455, by root42
Sure thing. Here it is:
✘-1 ~/Desktop/TandySound
20:20 $ avrdude -c usbasp-clone -p t13
avrdude: warning: cannot set sck period. please check for usbasp firmware update.
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.00s
avrdude: Device signature = 0x1e9007 (probably t13)
avrdude: safemode: Fuses OK (E:FF, H:FF, L:6A)
avrdude done. Thank you.
✔ ~/Desktop/TandySound
20:20 $ avrdude -c usbasp-clone -p t13 -B 60 -U flash:w:tiny13.hex
avrdude: set SCK frequency to 16000 Hz
avrdude: NOTE: "flash" memory has been specified, an erase cycle will be performed
To disable this feature, specify the -D option.
avrdude: erasing chip
avrdude: reading input file "tiny13.hex"
avrdude: input file tiny13.hex auto detected as Intel Hex
avrdude: writing flash (196 bytes):
Writing | ################################################## | 100% 0.12s
avrdude: 196 bytes of flash written
avrdude: verifying flash memory against tiny13.hex:
avrdude: load data flash data from input file tiny13.hex:
avrdude: input file tiny13.hex contains 196 bytes
avrdude: reading on-chip flash data:
Reading | ################################################## | 100% 0.07s
avrdude: verifying ...
avrdude: verification error, first mismatch at byte 0x0000
0x00 != 0x09
avrdude: verification error; content mismatch
avrdude: safemode: lfuse changed! Was 6a, and is now 0
Would you like this fuse to be changed back? [y/n]
avrdude: safemode: hfuse changed! Was ff, and is now 0
Also see the picture below for my setup.
487.71 KiB
460.45 KiB
YouTube and Bonus
Reply 78 of 455, by matze79
What if you simply use usbasp as programmer not -clone ?
i have seen this message before, but only with defective tiny's or bad/loose wiring.
Reply 79 of 455, by root42
It was the -D parameter... The erase cycle did not seem to be necessary or did not work. After specifying -D the verification succeeded. I will buy two 47nF tomorrow and finish the boards. Then I can try them out...
What do I need softwarewise? Can I simply fire up Zak McKracken or Maniac Mansion and it will detect the card?
YouTube and Bonus
