First post, by Moogle!
Not affiliated with the auction in question, I was just curious about this:
http://i.ebayimg.com/images/g/nK8AAOSwdvpWD08E/s-l1600.jpg
What's up with the bottom ISA slot?
Hah, good one! 😁
Seriously, though, that could be a proprietary 32-Bit slot.
Some 386es also had them (for memory boards, etc.)
Well, that was my first thought as well, but again, on a 486 with on board SIMM sockets?
Though now that I think of it, I've seen it on a Compaq that I used to own, but the proprietary slots were different. It was a PCI/MCA style slot on the end with a 6 pin ISA style slot further back.
Another glance at the picture with the LIF socket suggests it is an older 486. I missed that the first time around.
It's so when you want stereo Adlib cards you can throw them in back to back.
Jk. My thought is a proprietary system bus. Maybe some special multimedia function advertised as part of an OEM deal.
It's most likely a memory expansion interface. You can see traces from it snake its way to the SIMM slots. Looks like it's compatible as a normal 16-bit ISA slot too, since you see the left side of the 16-bit connector being tied up with the ISA bus.
386:
- CPU: 386DX-40 (128kB external L1 cache)
- RAM: 8MB (0 waitstates at 40MHz)
- VGA: Diamond SpeedSTAR VGA (ET4000AX 1MB ISA)
- Audio: SB Pro 2.0 + GUS 1MB
- ISA PS/2 mouse card + ISA USB card
- MS-DOS 6.22 + Win 3.1
- MR BIOS
wrote:Well, that was my first thought as well, but again, on a 486 with on board SIMM sockets?
Some boards, like the Asus ISA-386C, have onboard SIMM sockets but also options for an external memory card.
