Fake cache RAM... on Pentiums?
First post, by Tyrantulas
Is fake cache memory even a thing on Pentium boards?
This ATC-1000 board supposedly has 256k of integrated cache.... but when I add a 256k COAST module, the machine pretends that it can't see it. CHKCACHE confirms that it still sees only 256k of cache.
If I pull the tag chip, the motherboard claims there is no cache (same as turning off external cache through BIOS), and CHKCACHE confirms that it detects no cache.... and some basic benchmarking (using PhilsComputerLabs' benchmarking suite) shows that SOMETHING has changed performance-wise... maybe a 3fps drop in PC Player Benchmark.
No mobo tag, drop in the COAST module, the machine sees 256k cache, and CHKCACHE confirms that it detects it to.
What am I doing wrong?
(The cache module I have has exactly the same chips on it as the mobo does)
86.56 KiB
91.11 KiB
Reply 1 of 27, by Deksor
I've never seen bad ATC boards. Maybe they've done some but I never heared of them then. Looking at your board, I can see two UMC chips that should be the sram chips for the cache.
Prehaps there's something wrong with the cache configuration
Reply 6 of 27, by Deksor
Sure companies faked cache, but as far as I know, ATrend didn't do this and in the photo I can see two UMC chips that looks like regular SRAM chips. Usually they did show "Write-Back" on them and that was all.
Take a look at the manual (I've found this http://www.elhvb.com/mboards/a-trend/manuals/index.html), maybe some jumpers are set incorrectly ?
Reply 7 of 27, by lazibayer
The COAST has 32k x 8 tag ram which is plenty for 512KB cache. You should pull out the onboard tag when the COAST is inserted.
What's the label of JP1 on the COAST? Perhaps you need to toggle the jumper cap in order to make things work.
Reply 8 of 27, by Baoran
I had a very similar motherboard and I always thought that it was normal that the coast module replaces any on board cache and they do not work at same time. That is why I got 512Kb coast module to begin with.
Reply 9 of 27, by lazibayer
It's tricky to get COAST work along with onboard cache without a clear manual. We may have to inspect the features of the board and the stick:
1, board has removeable tag ram? - yes in OP's case
2, size of onboard tag? - can't tell
3, onboard jumpers that configure cache size? - seems not
4, stick has tag ram? - yes
5, size of stick tag? - 32k x 8, enough for 512KB cache
6, stick has jumper? - yes, but can't read the label
Reply 10 of 27, by Tyrantulas
lazibayer wrote:
Th jumper is marked "linear" and "interleaved" modes.
interleaved is the default operation mode. Linear causes the machine to crash the second it displays the system summary after the main bios screen... it doesn't even fill out the fields... just draws the ASCII frame and then hard locks.
Reply 11 of 27, by Tyrantulas
Here are some closeups for part numbers:
Motherboard cache + cache module -
1.46 MiB
Motherboard TAG chip -
1.83 MiB
Thanks again!
Reply 12 of 27, by Deksor
This confirms what I said, the two UMC chips doesn't look anywhere close to fake cache chips and puting a real tag ram would be pointless if they faked the cache. There's probably something wrong somewhere, but the board doesn't have fake cache for sure
Reply 13 of 27, by lazibayer
It should be set to interleaved mode. Have you verified the onboard cache with CHKCACHE, without COAST being inserted?
Reply 14 of 27, by Tyrantulas
Onboard cache, with TAG in:
This machine appears to have both L1 and L2 cache.
L1 cache is 8kb
L2 cache is 256kb
Onboard cache, with TAG out:
This machine seem to have one cache?!
?! is 8kb
COAST, with TAG in:
L1 cache is 8kb
L2 cache is 256kb
COAST, with TAG out:
L1 cache is 8kb
L2 cache is 256kb
Reply 16 of 27, by mrau
the manual says it should work if you remove the onboard tag chip first; the manual speaks of kit-256 coast module - is that the one you utilise? if possible try putting the onboard tag in place of the one on the module?
Reply 18 of 27, by lazibayer
Tyrantulas wrote:
My second COAST module just arrived in the mail... it's identical in design to the first unit, and gives identical results in testing 🙁
Well your onboard cache is definitely real. The board might just doesn't like that COAST... Why don't you try another design?
Your onboard tag is 16k x 8 and sufficient for 512KB cache; so you could try a COAST without on-stick tag.
