First post, by Oldskoolmaniac
Every time windows boots up there is a box that pops up configuring windows, when it goes away desktop refreshes and my wallpaper is gone nothing but a solid background color.
Could it be cause im using a .jpg image Is .bmp recommended?
Motherboard Reviews The Motherboard Thread
Plastic parts looking nasty and yellow try this Deyellowing Plastic
Reply 1 of 11, by Jorpho
Why don't you just try it and find out!?
I think JPG wallpapers required IE4 (Active Desktop).
Reply 2 of 11, by Oldskoolmaniac
I did and still same issue and I have IE5.5 installed.
Reply 5 of 11, by subhuman@xgtx
I think there's an update that causes this glitch. The same happened to me when I had 95c installed on my pentium mmx system.
Reply 8 of 11, by Oldskoolmaniac
I don't see active desktop anywhere.
I'm using win95c with the unofficial service pack and IE5.5.
When win95 logs in there is box in the corner that says "windows is now setting up the following item" my desktop refreshes then goes to a solid color background.
    26.6 KiB
Reply 10 of 11, by Jorpho
You should check which items are running at startup, or just check Task Manager to see if there is anything unexpected running.
Reply 11 of 11, by Oldskoolmaniac
Got it working, had to reinstall everything like this Win95->IE4.01->IE5.5->SP1 Now everything is working great! I had no idea IE4.01 would change the whole explore layout.
Had to reinstall windows, i did the exact same same route and now im getting that same problem i cant even change to a solid background.
