First post, by bjwil1991
So apparently yesterday, I decided to swap around my 40GB Maxtor HDD that was in my iMac G3/600 that was installed in an external HDD enclosure (Maxtor OneTouch) and the 200GB Western Digital Crashier HDD, connected the USB cable to my Windows 10 desktop, and when I was trying to copy files, it would just cancel itself out and nothing goes into the folder I have in my 1TB HDD.
I even tried doing a CHKDSK command, and everything went south. There were tons of errors, and when it was trying to reallocate the files on the HDD, it would tell me there's insufficient space on the HDD to fix those files. When I booted into a Live version of Lubuntu 17.04 on my desktop with the HDD hooked up internally, there were 3 failures or failing attributes within the SMART test and it also says:
This hard drive is likely to fail soon.
And on top of that, it also says the partition is "Unknown", but in Windows 10, it detects the HDD and partition says it's NTFS. Right now, I'm testing a program to see if it'll copy the files onto my hard drive, and the transfer rate is 28Bpss (Bytes per second) and write attempts are good, it just won't read the files... And all of the files that are on the HDD are very important since it has iTunes stuff on there, like movies, TV shows, music, as well as pictures, drive backups from the past, etc.
The HDD was manufactured in December of 2006, and it's July of 2017 and it's odd that it's failing, and 4 years ago, I did a CHKDSK on the HDD and it fixed 3 files that were bad and everything copied over to the server's HDDs without issues, decided to format the HDD, and copied everything back over to the HDD and it passed every SMART test. I believe when it sits in storage the drive is likely to fail over time.
I have a 428.1MB Seagate HDD that was pulled out of my Packard Bell Pack-Mate 28 Plus (about 20 or so years old) since I upgraded to a CF card as a hard drive (SSD) and that hard drive still works and passes every test.
80.22 KiB
Well, shit!
Reply 1 of 11, by luckybob
You are about to learn one of the hardest lessons in computers. Portable drives are SHIT for backups. Everything "important" is kept on two different tape drives each stored at a different place. I keep one in a safety storage bin at the bank, the 2nd at a friends house.
a 11 y/o drive failing is NOT odd. Double so for a portable one. The key here, is the portable part. They ALWAYS get bumped, dropped, kicked, etc while running and it always causes them to fail fast. That old drive in that Packard Hell, probably has as much actual run-time as that portable drive you have. Not to mention it probably sat on a deck and never fell off.
Reply 2 of 11, by cyclone3d
It could be the external enclosure itself that is dying and not really the drive.
Any time an external drive starts giving me trouble, I take it out of the enclosure and either hook it up via some sort of dock or just hook it up directly to the controller on the motherboard.
I've seen quite a few drives that worked fine once they were taken out of the enclosure.
Sometimes the enclosure controller itself goes bad and sometimes it is the power supply.
It is at least worth a try to see if it will allow you to get your data off.
If that doesn't work, you can always try a used controller board off of the same exact model hard drive. The boards are generally available on eBay.
Barring that, the only thing to do is to send it into a recovery company and spend big bucks to try to get your data back.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 3 of 11, by bjwil1991
cyclone3d wrote:
It could be the external enclosure itself that is dying and not really the drive. […]
I hooked up the HDD to my motherboard and it's the same sob story. I diagnosed the logic board, and surprisingly, it's in good shape. Should I just purchase a logic board on eBay for the drive? I also have software on my desktop to recover the files off of a hard drive. I had a hard drive crap out on me before, and after running MiniTool Partition manager's HDD checker, I got all of my data off, and the HDD had over 1 million bad sectors, but the SMART test was still good surprisingly.
Reply 4 of 11, by Ampera
As amazing as it sounds I have never once had a hard drive die on me. Data loss? YES, outright death? No.
Just keep trying stuff. Imagine the drive is one idea. Using GParted to recover lost data is another.
Sometimes hard drives just break so fast you can't get the data off of them. If you want good backup media for older PCs, QIC-80s are cheap and easy.
Reply 5 of 11, by Deksor
On some HDDs there are some pins on the back that are there for a serial connection. I heared that you can retrieve your data from there though it's going to take ages since the fastest it can go is probably 115200 bits per seconds
Reply 6 of 11, by clueless1
PhotoRec on the Hirens Boot CD does pretty good at recovering files. A simpler, but less effective one is Recuva from Piriform.
luckybob speaks words of wisdom...agree 100% with everything in his post.
If you're desperate to recover data and not having luck, you can try SpinRite. It's $90, but there is a money back guarantee if it doesn't work for you. There's another one called HDD Regenerator that I've heard some people have success with, but I've never tried it myself.
edit: some links that may help:
https://softwarerecs.stackexchange.com/questi … ailed-hard-disk
https://softwarerecs.stackexchange.com/questi … ion-of-spinrite
Reply 8 of 11, by Ampera
If there is some actual serious stuff you need off that drive, and it's worth money to you, you can always bring it to a data recovery service. Tampering with the drive further can often lead to less of a chance they can do anything.
Reply 9 of 11, by chinny22
I've got a 1TB WD external drive that started doing similar things, can write fine but certain folders couldn't be read, and was affecting more and more as days passed.
So plugged the HDD direct to the motherboard and copied everything across fairly quickly.
I tried a 2T and a 500 B drive connected to the SATA to USB converter and both did funny things, cant remember what now but enough not to trust the adaptor anymore and gave up.
It all comes down to the drive cant be trusted at the moment, its lying to you one way or another! ignore smart test, chkdisk or whatever. get the files or an image off the drive onto something known to be good however you can.
anything that changes on the drive has a 50/50 chance of corrupting things more.
Reply 10 of 11, by hyoenmadan
Sound like this drive has a serious mechanical disease, and is starting to corrupt the Service Area Cylinder software modules (in modern HDDs the logic board microcontroller software isn't stored in an eeprom, but in a special track inside the HDD so them can be updatable when microcontroller needs it).
So, the more you try to tamper with the drive, the more corrupt the SA and subsequent cylinders will become, and the less chances you can get anything from it. Just send the damn thing to Recovery Services. Hardware problems can't get solved with software tools.
Reply 11 of 11, by Errius
Does the freezer trick work on modern drives? I got data off a 20 year old drive this way. It took about a week of daily freezing and data reading, but I eventually managed to recover nearly all the files on it.
Is this too much voodoo?
