Old hardware giveaway thread.
Reply 180 of 1232, by liqmat
Up next on the cookie cutter is a MSI MS-6905 Master CPU Converter Board also referred to as a Slotket. (also incorrectly referred to as a Sloket, Slopit, Snotit and/or Stopit) This is the highly compatible and sought after Version 2. This one was used only a handful of times for testing different CPUs and still looks new. Worked great when last used.
Guess a number between 1 and 20 every 15 minutes and you get the prize if correct.
Once again, U.S. addresses only.
971.39 KiB
930.79 KiB
Reply 185 of 1232, by liqmat
F2bnp wrote:
Wish I was a US resident for this 🤣
Something this small I might be able to get cheap shipping. I might have another one of these.
Reply 187 of 1232, by sd_entertainmnt
liqmat wrote:
sd_entertainmnt wrote:
Or 37?
Sleigh bells ring! Motherboards are glistening! That is correct! PM me a U.S. address so Rudolph can deliver.
Wooohoooo! Thank you Santa!
Reply 188 of 1232, by bjwil1991
Interesting topic.
Reply 189 of 1232, by liqmat
Now for something completely different. How about a box full of memories?
Most untested, but all came from working machines. The Pentium III 450 CPU was tested and works great.
Thinking of a color.
First correct guess gets the following. Guess every 10 minutes.
19 512MB Sticks of Nanua PC2-4200U-444-12-A1 DDR2 Desktop RAM
3 512MB Sticks of Hynix 1Rx8 PC2-5300U-555-12 DDR2 Desktop RAM
3 512MB Sticks Infineon 1Rx8 PC2-4200U-444-11-A1 DDR2 Desktop RAM
1 512MB Stick Ramaxel 1Rx8 PC2-5300U-555 DDR2 Desktop RAM
4 512MB Sticks Hynix 2Rx16 PC2-4200S-444-12 DDR2 Laptop RAM
1 512MB Stick Hynix 2Rx16 PC2-5300S-555-12 DDR2 Laptop RAM
2 512MB Sticks Samsung 2Rx16 PC2-5300S-555-12-A3 DDR2 Laptop RAM
1 512MB Stick Samsung 1Rx16 PC2-5300S-555-12-C3 DDR2 Laptop RAM
2 256MB Sticks Samsung 1Rx16 PC2-4200S-444-12-C3 DDR2 Laptop RAM
4 Random Sticks Of Laptop RAM (512MBx3, 256MBx1)
...and two CPUs
1 Pentium II 400MHz 512K CPU 80523PY400512PE SL2U5
1 Pentium III 450MHz 512K CPU 450/512/100/2.0V
681.61 KiB
Reply 196 of 1232, by liqmat
Found another MSI MS-6905 Master CPU Converter Board. This is the highly compatible and sought after Version 2. Used only a few times for testing CPUs. Basically brand new.
971.39 KiB
930.79 KiB
Reply 197 of 1232, by clueless1
Reply 199 of 1232, by clueless1
