The way to detect OPL3 clone
First post, by nukeykt
Today i wrote program that can help to detect OPL3 clone. This program plays simple 440hz sound. It sounds like simple sine wave on OPL3 and like FM sound on clones. This program relies on hardware bug that presents in the real OPL3 core. I've tested it on YMF718 and various emulators.
Report your results here. I'll add them to this list.
Results:
YMF718 - Pass
DOSBox Fast core - Fail
DOSBox Compat core - Fail
Nuked OPL3 v1.7.4 - Fail
Nuked OPL3 v1.8 - Pass
CMI8738 - Pass
YMF744 - Pass
ESS1938 - Pass
FM801 - Fail
ALS4000 - Pass
MediaGX CX5530 - Fail
OPTI82C931 - Fail
CS4236 - Fail
AD1868 - Fail
ALS100Plus - Pass
ALS300 - Pass
CT1747 - Pass
YMF262 - Pass
CQM - Fail
YM3812 - Pass
ES1370 - Fail
ES18178 - Pass
VirtualPC - Fail
VMware - Fail
Download:
oplclone.zip
10.75 KiB
267 downloads
Samples:
YMF718:
oplclone_ymf718.mp3
243.96 KiB
239 downloads
DOSBox fast:
oplclone_dosbox_fast.mp3
156.53 KiB
216 downloads
Reply 3 of 41, by James-F
If you can/want/will, please provide a patch in .diff form when it's ready so it can be implemented in DOSBox ECE.
The current iteration of nukedOPL is already remarkably close to the original even in RTF measurements, I thought it was bit perfect already.
Reply 4 of 41, by Stretch
I cannot hear a difference between the 3 sound cards I recorded from. I ran the program under Windows 98 SE command.com
    oplclone_ymf744.mp3
    268.13 KiB
    156 downloads
    Yamaha YMF-744
    oplclone_ess1938.mp3
    261.22 KiB
    151 downloads
    ESS Solo-1
    oplclone_cmi8738.mp3
    237.75 KiB
    164 downloads
    CMI 8738
Win 11 - Intel i7-1360p - 32 GB - Intel Iris Xe - Sound BlasterX G5
Reply 5 of 41, by nukeykt
Interesting results. YMF744 has real OPL3 so no question here. CMI8738 is believed to have real OPL3 and this recording confirm it. But ESS1938 is surprising. Perhaps they were aware of this bug. Does this card use hardware FM synthesis, or FM is emulated in software?
Reply 6 of 41, by Stretch
nukeykt, ESS Solo-1 has hardware FM synthesis. Here's a screenshot of the FM port settings in device manager.
Reply 7 of 41, by nukeykt
How accurate it is? Or it is just ESFM?
Reply 8 of 41, by Jo22
Is that 2K/XP w/ classic theme or Win9x ?
I owned a TT-Solo and FM sounded not so well with the built-in XP drivers.
Reply 9 of 41, by Kamerat
Here's the ALS4000 PCI sound card, the FM synth should be the same as the ALS120. Sounds legit.
Edit: Also added the FM801-AU, doesn't come close to the real deal...
    oplclone_fm801.mp3
    121.36 KiB
    145 downloads
    oplclone_als4000.mp3
    162.18 KiB
    150 downloads
YouTube channel
Reply 10 of 41, by nukeykt
Added, thanks.
Reply 11 of 41, by SaxxonPike
Fascinating results! Thanks for all your hard work, nukeykt, and the rest of you for running these tests.
Sound device guides:
Sound Blaster
Aztech
OPL3-SA
Reply 12 of 41, by Stretch
Windows 98 SE. When I installed the unofficial service pack I picked the Win2k theme.
Reply 13 of 41, by Jo22
Here are some MP2 recordings for you. Opti 82C931 and MediaGX.
Ah, okay, thanks ! 😀
Edit: Quote fixed. 😅
    oplclone_mediagx_cx5530.mp3
    328.29 KiB
    163 downloads
    oplclone_opti82c931.mp3
    275.27 KiB
    149 downloads
Reply 14 of 41, by Kamerat
MediaGX sounded just like the SiS 7018. 😳 In Doom there's actually some noise. 🤣
YouTube channel
Reply 15 of 41, by Stretch
I uploaded 2 more. Not sure why my recordings are so much lower than the others.
EDIT: I think we have to disregard these 2 because it seems my PC with ISA slots is not grounded properly.
Now the last major missing cards are YMF-262 and CQM.
    oplclone_ad1816.mp3
    273.47 KiB
    55 downloads
    Analog Devices AD1816AJS SOUNDPORT from Aztech SC16-3d
    oplclone_cs4236.mp3
    322.45 KiB
    133 downloads
    Crystal CS4236
Reply 16 of 41, by Jo22
One more recording. ALS100+, with built-in OPL3 (the chip can also be paired with an external YMF262). It's the "fixed" card used in this thread.
Cool, thanks for letting me know! 😀
I guess this chipset was also used in Pentium III machines, since my dad's "year 2000" PC had a SB16 setting in BIOS.
https://en.wikipedia.org/wiki/SiS_630/730
Reply 17 of 41, by Jo22
And another one, again. ALS300 w/ built-in OPL3 core..
    oplclone_als300.mp3
    437.38 KiB
    152 downloads
Reply 18 of 41, by Jo22
Creative "OPL", CT1747..
