First post, by DracoNihil
I have a cheap chinese clone PCI-e CMI8738 soundcard, the OPL3 actually functions and ALSA uses it for MIDI output (when FM timbres are loaded into memory beforehand), as far as I can tell it's running in OPL3 mode and not OPL2 mode.
Can programs directly access the registers even though ALSA is using the OPL3 for MIDI? Is it possible for me to switch the thing into "OPL2" mode? Can I use "passthrough" code so things like DosBOX, adplug, etc use the CMI's OPL3 chip rather than a software emulation?
― Κυνικός Δράκων
Reply 2 of 12, by DracoNihil
Well ALSA has to be "directly accessing the hardware" to even beable to use the OPL3 because you have to write to it's registers to make it produce sound. I get that it's not a "normal thing" but that's not answering if what I want to do is feasible enough. I already seen working passthrough on Windows NT based systems using either special drivers or Ring 0 "rootkits", but never under Linux...
― Κυνικός Δράκων
Reply 4 of 12, by DracoNihil
Hey guess what, it is possible. Though it can be only done under root (and I'm not sure what the specific capability\permission is to make non root users able to access this)
3.73 KiB
Though the port is not 0x388 but instead 0xD050 according to NukeYT.
Now I just need to find more software to test this with. I hear Chocolate Doom has support for direct OPL access. Is there a build of adplay for Linux that has it as well?
― Κυνικός Δράκων
Reply 5 of 12, by Scali
Since it's a PCI-e card, and not a legacy ISA card, I'm not too surprised that it uses a different port range.
Reply 6 of 12, by root42
Root can do IO on ports, but that is not very neat. You might have a raw device under /dev/snd, such as /dev/snd/fmCxxx, where the xxx stands for the Alsa card. But that depends on the driver, and I have not used it. That device should be an abstraction of the OPL3 ports into the device file system, so that you do NOT need root privileges. I don't have any Linux machine with such a configuration on hand though, so take it with a grain of salt...
YouTube and Bonus
Reply 7 of 12, by DracoNihil
CMI8738's were never ISA to begin with as far as I know. They were among the first PCI only soundcards with dubious SBPro2 backwards compatibility.
I only get the following in that directory (I don't even know that much about ALSA to begin with either):
by-id    controlC0  hwC0D0    pcmC0D0c  pcmC0D1p  pcmC0D2p  seq
by-path controlC1 midiC0D0 pcmC0D0p pcmC0D2c pcmC1D0c timer
And I know there is a way to specify permissions a process name can access (I had to do this to permit Wine's processes to bind ports 0-1024) but I don't know what the name of the permission is to grant.
― Κυνικός Δράκων
Reply 8 of 12, by root42
DracoNihil wrote:
I only get the following in that directory (I don't even know that much about ALSA to begin with either): […]
Do a 'ls -l /dev/snd' and you will see that all those devices have group id "audio". So you just need to make sure that the processes you are running are run by a user that is in the audio group.
It is also very hard to find information about low level FM / OPL2 / OPL3 access in Linux. But I guess someone might be able to write a simple device driver... That would actually be a neat project, come to think of it...
YouTube and Bonus
Reply 9 of 12, by DracoNihil
I mean, you can look at vgmplay's source code for how they're directly writing to the registers.
As far as drivers go, ALSA just has a driver for using the OPL3 as a "General MIDI" device. Somehow this driver also works around bridge chip usage, despite the driver having the "fm_port" set to 388...
― Κυνικός Δράκων
Reply 10 of 12, by root42
Concerning vgmplay: you should be able to run it without root privileges after setting the capabilities:
sudo setcap vgmplay CAP_SYS_RAWIO
Also not tested, but it should give the process to call ioperm() -- which it does, according to the source in ChipMapper.c -- and hence be able to write directly to the OPL2/3.
YouTube and Bonus
Reply 11 of 12, by DracoNihil
In my case the invocation is:
sudo setcap cap_sys_rawio+ep ./vgmplay
Thanks for pointing me out what the capability was named, no need to constantly sudo vgmplay. I'm going to assume it'll be the same case for Chocolate Doom's direct OPL access too, and anything else using the raw IO syscalls or whatever.
― Κυνικός Δράκων
Reply 12 of 12, by root42
Yes, should be the same. Sorry for the wrong syntax. I did that from memory... 😒
YouTube and Bonus
