First post, by Rodoko
Since it passed a long time when I posted here @ Vogons I decided to return and show you guys something
On the last Thusday I was talking with the owner of a computer parts store to see if they had an AT case or a parts computer and he told me that had 3 machines that were HP Vectras and they were stored in a closet and they were dirty as hell, so of the 3 I picked up the most complete one that came with a bonus, a 3com NIC!!
I tested it with the owner friends at the store, he configured the date for me and the original Sony battery amazingly has charge in it to keep up the date correctly x3
Has the original floppy and Noisegate 8.4 GB hard drive but sadly the processor was downgraded from the 450 MHz PIII to a 350 MHz SECC2 (Rare variant) PII, it had some PC133 RAM that the chipset didn't support so it took half of the RAM that was in the modules
When I took it to home it wasnt turning on or showing an image so instead of going with diagnostics and giggles I decided to spend the whole afternoon cleaning it the best I could using these stuff
  • Paint brush
    Garden hose & water
    Q-tips & alcohol
    Me acting as a compressor blowing some air with a transparent tube
    And last and least, a kitchen cleaner and a cloth
So as of now the system recieved some surprises during the days I worked on it that I will show later to you people at the end of this post, for now, some pics I took (Rotate your heads or click on them to see on normal position, they were took vertically, I feel sorry for your neck pain)
505.85 KiB
Picture I took at the subway when I was ready to take it to home, you can see that it mentions of having a PIII while in reality the original owner swapped it with a PII
564.74 KiB
That's soooo nasty eww, take a look at Dustland
4.53 MiB
When I did took out the NIC some serious dust did fall into the slot .-.
4.91 MiB
Closeup of the custom front panel connection, thanks to God that it uses standard housing so in case that the PSU blows up I can modify the replacement case's front panel connectors to adapt them to this housing :3 and also you can see the dust that this thing had
After cleaning the PSU and the board using myself as a compressor with the tube and blowing and the paint brush it became nice and clean (PSU is a 90W LiteON BTW)
595.08 KiB
Motherboard outside of the case with the PSU hooked up and a 256 MB test module to give 128 MB for startup
It continues in the next post :3
Reply 1 of 5, by Rodoko
Continuation from the first post owo
459.73 KiB
It works!! (The computer on the bottom of my monitor is my PII 400 with a Voodoo Banshee card)
The board uses standard Award BIOS and it was made by Mitac in Brazil
429 KiB
The case all cleaned up after spraying it with a garden hose and let it dry for some minutes, you can see that has some centering pegs which are cool since they let you to align the motherboard much easier, but for me it was kind of a nightmare
649.22 KiB
Putting the machine back together :3
676.51 KiB
All built together with the 3com NIC that was originally in the machine
I also cleaned the floppy drive heads but I didn't took a pic of the process uwu
Then I did run the Hard Disk Sentinel tool to check the Seagate's health and it was in perfect condition x3 (100%, amazing for a 18 year old drive that also is original to the machine!!)
And last and least I did bootup the machine from the HDD and it had an installation of Windows 2000 that was cleaned on personal documents and it had a password so with the help of HBCD I did get it to crack it open (hehe x3 ) and it didn't had personal info but it was soooooo slow as a snail, it had Slowrton AntiVirus, Office 2003 and management software for a HP flatbed scanner
So I formatted it and installed 98SE with the appropiate drivers for the Matrox 8MB onboard video chip (Yes, the board aside of not having AGP slot at least has onboard video with his own memory) and the Crystal built-in audio that I replaced with an ISA ESS card (Made for Compaq machines) that has an internal speaker output) and I added 256 MB PC100 RAM
4.07 MiB
The larger ESS card and behind it is the 3com NIC
The machine is silent absolutely no noise at all except for the HDD that is noisy while seeking and R/W activity
Reply 2 of 5, by Rodoko
Continuation for the second post
To make it better I did fix the original aftermarket CD-ROM drive that it came with
3.81 MiB
Beware while doing this, I did save the spindle from a junk drive and the belt came from a Samsung drive since I have two of them
4.15 MiB
Front panel closeup
3.61 MiB
The machine as of now, is so small in height when compared to a standard desktop PC of the era :3
Reply 3 of 5, by oeuvre
Use a magic eraser on the exterior of the case to remove scuffs and marks. Works wonders.
Reply 4 of 5, by chinny22
SFF'S make great "backup" PC's
I'm about to rebuild 2 P4 based Compaq Ev0 510's as fallback Win9x/DOS Gaming PCs
OK we are limited in graphics card choice (you without AGP and me with the 1/2 height card limit) so wont play the most demanding Win9x games but I have my main rig for that. These will be used for network gaming and being small and stackable can be stored away when my friends all go home.
The fact you have an ISA slot is even nicer though, and even the P2 will be fine for all your dos gaming needs
Reply 5 of 5, by Rodoko
UPDATE 04/24/18
This machine finally recieved a proper PIII and now is dualbooting Spanish Win98 SE together with Jap. (日本語) Win98 SE
Also it got a USB 2.0, a much nicer 3com NIC and my trusty SBLive
