First post, by kanecvr
Hi guys. I want to introduce this forum to a lovely little motherboad that can run most 90's 5x86 (pentium class) cpus, and downclock most chips to 10.66MHz for XT level performance.
Meet the Lucky Star 5V-1A:
260.2 KiB
Features and sepecifications:
- Socket 7 CPU's supporting anything from a pentium 75 up to a K6-II/III at 570MHz*
- PS/2 mouse port
- USB 1.0
- 4x PCI slots
- 3x ISA slots
Chipset: VIA VPX + Via 586B southbridge (no ATA bug)
FSB speeds: 8*, 50, 55, 60, 66, 75, 85, 95* (* means undocumented)
Core voltage: form 2.0 to 3.53 V in 0.1V incerements, single or dual voltage CPU
RAM: 2x 72 pin SIMM slots witch take FPM or EDO + 2x SDRAM slots witch take modules up to 256MB in size
L2 Cache: 256kb or 512kb
Maximum memory: 512MB (2x256MB double sided SDRAM)
What makes this board special? The undocumented jumper setting for 8MHz front side bus. With this you can run a pentium CPU at 10.66Mhz with the PCI bus at 4MHz yearling XT levels of performance on a machine cabable of running a K6-II 400 @ 6x66Mhz and faster. At it's fastest documented jumper setting, FSB 75, the board can run a K6-II at 450Mhz (75x6) and maintain the PCI bus fequency at 32MHz, pretty close to the 33Mhz default. At 83MHz PCI is overclocked slightly to ~35.6Mhz witch most PCI cards should have no problem with due to an odd PCI bus multiplier setting of 2.33X witch is enabled when selecting 75 and 85MHz FSB. At 95Mhz (for those lucky enough to have this clock setting stable, since that entails a pretty big overclock to the chipset and L2 cache) you can run a K6-II CPU at 570MHz. My board is not entirely stable at 95MHz FSB - for that I need to disable on motherboard L2 cache, but that's not an issue when using CPUs with on die L2 cache like the K6-II+/K6-III.
I've compiled a document with extended jumper settings from various sources and personal experimentation as well as PS/2 port pin-out and more:
LUCKY STAR 5v-1a Manual.pdf
583.11 KiB
515 downloads
Also, here is the latest BIOS version (J3-006) witch allow for larger disk drives and allows the board to correctly identify and use SD-RAM modules:
J3-006.rar
106.36 KiB
240 downloads
And stock bios witch came with my board:
5V-1A bios.rar
104.76 KiB
187 downloads
Before attempting to flash BIOS, please note that this board usually comes with a one-time flashable Amtel EPROM chip - witch means you will need another 5V 128kb EEPROM to update bios.
Reply 1 of 29, by kanecvr
Time for benchmarks! While running a 400Mhz K6-II (2x66), the board performs surprisingly well. The following system configuration was used:
AMD K6-2 400 running at 400MHz 6x66Mhz
128MB SDRAM PC100 (2x64MB) running at 66MHz CL2
ELSA S3 Virge GX 4MB
STB 3dfx Voodoo 2 12MB
Guillemot Maxi Sound 64 Game Theater (ES1868 + Dream 9250)
Results:
- Speedsys CPU score: 457.30 points
- Speedsys memory bandwith: 210.58 MB/s
- Speedsys memory throughput: 127.96 MB/s
- Speedsys L1 Cache: 1135.76 MB/s
- Speedsys L2 Cache: 181.73 MB/s
- 3D Bench: 196.4 FPS
- PC Player Benchmark 320x200: 72.2 FPS
- PC Player Benchmark 640x480 VESA mode 101: 27.2 FPS
- Quake 1.08 (DOS) 320x200: 59.9 FPS
- Quake 1.08 |(DOS) (640x480): 25.9 FPS
- GL_Quake 0.97 (640x480): 50.4 FPS
Reply 2 of 29, by kanecvr
Now for the interesting part - benchmarking with a pentium CPU, using the 7.15MHz FSB option. I ran the tests with and without cache. I only ran speedsys, 3dbench and PCConfig, since running PCP or quake would have taken far too long.
Some quick notes before I list the benchmark results:
1. Counting ram takes forever - also, the machine will freeze when counting ram if more then 64MB of ram is used.
2. Everything slows down, including the beep when the PC posts, witch is now elongated. It also takes a 2-4 seconds for the machine to post, and another 1-2 to display the VGA bios.
3. PCI cards seem to run fine at 7.15MHz - I've had no issue with the virge. It also seems to slow the card to early XT 8bit ISA display adapter speeds
4. The K6-II 400 can only run at 17.8MHz as it's slowest speed since 2x is interpreted at 6x and 1.5x is interpreted as 3.5x - as such, 2.5x7.15 is the slowest configuration it will run at. For best results I decided to use a 166 Mhz Pentium (non-MMX).
5. BIOS incorrectly reports the CPU running at 50MHz.
Now for the results:
Part A - 10.73MHz (7.15x1.5), L1 and L2 cache enabled:
Speedsys CPU score - 8.08 points - 386 DX40 levels.
3DBench: 10.5 FPS
PCConfig Drystones: 7200
PCConfig Whetstones: 2626
Part B - 10.73Mhz, all cache DISABLED
Speedsys CPU score - 0.83 points (lol)
3DBench: 0.8 FPS (test took forever)
PCConfig Drystones: 0 (dunno why this benchmarks as 0)
PCConfig Whetstones: 289
Reply 3 of 29, by bjwil1991
kanecvr wrote:
Now for the interesting part - benchmarking with a pentium CPU, using the 7.15MHz FSB option. I ran the tests with and without c […]
To summarize:
3DBench: 10.5 FPS
Interesting benchmarks. The last one looked like it was running at the XT speed or equivalent.
Reply 4 of 29, by kanecvr
Thanks. I posted them since I tough people might find a pentium running at XT levels interesting. With cache disabled, the machine is comparable to a NEC V20 cpu running at 12MHz.
I tried Lode and Digger on it and they both ran great.
Reply 5 of 29, by j^aws
Cool to see a Socket 7 and an IA32 CPU run so slow. Do you have any Norton Sysinfo benches?
If you do, then this would be great when compared to some other IA32 slow benches in this thread:
The IBM XT challenge: How slow can you go with i386+ (IA-32) CPUs?
The slowest Norton SI achieved was 0.3, which is around Speedsys 0.1 - a third of a 4.77MHz Intel 8088 or so ~ 1.5 MHz.
Reply 6 of 29, by kanecvr
j^aws wrote:
Cool to see a Socket 7 and an IA32 CPU run so slow. Do you have any Norton Sysinfo benches? […]
Don't have any, but I'll run some the first chance I get.
Reply 7 of 29, by watson
Hi, what kind of hard drive did you use with this board?
I bought an AT29C010A EEPROM and successfully flashed the J3-006 BIOS, but the board won't detect either a 40GB or 20GB HDD.
Both autodetection and manually setting it to LBA or LARGE hangs on boot.
I also tried messing with the cylinders/heads/sectors. Setting it to 16383/16/63 didn't work.
Also, I'm having a problem with using more than one PCI card.
If I plug in any card in addition to the video card (Ethernet, USB 2.0), the system resets randomly during memory test.
Reply 8 of 29, by root42
Love it. Underclocking is the new overclocking!
YouTube and Bonus
Reply 9 of 29, by BinaryDemon
It’s very cool that the motherboard has this capability but changing jumpers is such an awkward method for manipulating cpu speed especially if it’s something you want to do frequently. I’d have to do something like wire up a series of switches mounted on the front bezel.
Check out DOSBox Distro:
https://sites.google.com/site/dosboxdistro/ [*]
a lightweight Linux distro (tinycore) which boots off a usb flash drive and goes straight to DOSBox.
Make your dos retrogaming experience portable!
Reply 10 of 29, by Sphere478
How have I never heard of this?
This is amazing, are there any other boards that can do this?
Suggest installing a cyrix 366gp and using the 1x multiplier setting that those cpus have :p (other mII cpus have it also, in fact I think all socket 5/7 cyrix chips had it until they removed it on the 2.2v core chips
Btw,
Re: Socket 5/7 underclock! Aiming for the abyss!
Sphere's PCB projects.
Reply 11 of 29, by Sphere478
Anyone have a better pic of that clockgen? Or a datasheet for it?
Reply 12 of 29, by PcBytes
Sphere478 wrote on 2022-04-30, 06:45:
I managed to find it, it's an ICS9169CJ-27.
https://www.alldatasheet.com/datasheet-pdf/pd … S9169CJ-27.html
Reply 14 of 29, by Socket3
@kanecvr - could you please provide jumper settings? Turns out I have a similar if not identical board in my 66MHz fsb K6-2 build. I flashed the bios you linked and the board detected a 60GB drive with no issues, and now I'd like to try out the 8MHz fsb. I'm running a K6-2 475 in mine at 6x66Mhz with 128Mb of SDRAM.
I've had some problems with mine - had a voodoo 3 in it witch ran fine for a few months, then suddenly decided to crash whenever I ran a 3D accelerated game. Tested with a geforce 2 PCI and while that ran OK, performance was at pentium 166 levels (possible driver issue, the oldest diver I had at hand was 20 something).
Also mine came with a Winbond eeprom and had no problems updating the bios.
Reply 15 of 29, by janih
Socket3 wrote on 2022-04-30, 17:58:
The FSB jumper settings are in the pdf manual: download/file.php?id=39375 and also here: https://www.ultimateretro.net/en/motherboards/3486#downloads
Reply 16 of 29, by Socket3
janih wrote on 2022-04-30, 18:25:
I'm talking about the undocumented jumper settings OP used to get the board to do 8Mhz FSB.
Reply 18 of 29, by janih
Socket3 wrote on 2022-04-30, 19:32:
Ah sorry about that, my mind read the 8Mhz as 83Mhz 😀
Btw. If someone here has English manual of Lucky Star 5V-2, that would be nice to find. 5V-2 seems to be similar to this 5V-1A.
Reply 19 of 29, by Sphere478
PcBytes wrote on 2022-04-30, 07:33:
Did you find a better pic? I don’t see a 7 mhz option there.
