Reply 20 of 29, by Socket3
Ok, here we go - after some experimenting without any meaningful results, I had a second look at the manual (downloaded from this thread) to think of possible undocumented jumper combinations, and came across this:
54.94 KiB
It seemns @kanecvr was nice enough to add the jumper settings he found to the manual attached to this page!
If I would have taken the time to read his pots, I would have figured it out earlier. First setting in the pic witch I plucked from the LUCKY STAR 5v-1a Manual.pdf file in the first post clearly shows the "8mhz" jumper settings.
I tried the 8mhz setting myself but the PC would not post, so I read all of OP's posts. Turns out OP was using a pentium MMX, while I'm using a k6-2. I swapped my k6-2 for a 200Mhz pentium MMX and voila! When posting, bios says the CPU is a " " at 8MHz. Everything is SLOW!!! SOOOO SLOW! XT slow!
I'll run some benchmarks and post some pics tomorrow, right now I gotta prep for work.
Reply 21 of 29, by Babasha
Socket3 wrote on 2022-05-01, 17:17:
Ok, here we go - after some experimenting without any meaningful results, I had a second look at the manual (downloaded from thi […]
He-he… Is it same jumpers configuration for 8MHz and 60MHz FSB? Or what the difference?
Need help? Begin with photo and model of your hardware 😉
Reply 22 of 29, by Horun
Hmm from the data sheet everything in jumpers matches with 1-2 =0, 2-3 =1. Except it should be 0-1-1 for Ref/2 (Ref is the 14.3Mhz xtal) for ~8Mhz like this
    15.57 KiB
    33.95 KiB
Reply 23 of 29, by Sphere478
Horun wrote on 2022-05-01, 18:22:
Goot catch.
Can someone post a pic of the clock gen? And confirm that the datasheet posted earlier is correct? I’m assuming it is, just want to verify. I’m thinking of trying to order some of these for a experiment
Sphere's PCB projects.
Reply 24 of 29, by Horun
Sure ! See this one of the 5V-1A where it is very readable: https://www.ultimateretro.net/motherboard/ima … 11730668072.jpg
also found a picture of the 5V-2 which has ICS9169CJ-231 clock which does NOT have the REF/2 setting, instead it has two 75Mhz settings
https://pdf1.alldatasheet.net/datasheet-pdf/v … S9169C-231.html
added: the ICS9169C-23 (not 231 or -271) also has the REF/2 like -27 does....
Reply 25 of 29, by Sphere478
Excellent! Thank you!
Reply 26 of 29, by Jammers
I have a couple of questions:
My Pentium MMX 233 is currently set a 2.0Vcore. If I change the FSB or multiplier do I need to change the Vcore?
Has anybody tiried the USB headers. Is it similar to USB2.0 on a modern board, (1)5V(2)D-(3)D+(4)GND?
The P233 is also set at 3.5x multiplier. Do I need a CPU without the 3.5x to get to 1.5x?
Thanks
Reply 27 of 29, by Sphere478
Pentium mmx and tillamook don’t support 1.5x (at least through hardware)
Well binned pentium mmx p55c chips will often run at 2.0v but most of them are 2.45v-2.8v
The tillamook is 2.0v (1.9v)
Do you have a tillamook? If so, good find. You can set those to 4x 100mhz usually.
If you don’t know, post a pic of the back of the chip
Reply 28 of 29, by Volga163
Jammers wrote on 2022-09-15, 16:50:
Hey! I've got the exact same motherboard. What I can say about the USB header there - it's unusable on my motherboard because the ground pin on the header is not connected to the GND line (when I try to measure the voltage between +5V and GND pins, I've got 0V. But, when I decided to measure the voltage between +5V pin on the USB header and a ground pin on the LPT header - voila, the voltmeter showed me almost perfect 5 volts. I've got no idea was this intentional or just a failure on production lines. The official manual that I could find online didn't say anything about USB headers, just a little note that CN5 and CN6 are used for USB connection.
Reply 29 of 29, by BitWrangler
I am getting close to getting mine out for a play around and possible build. I noticed that for a different motherboard with a similar clock chip, the ref/2 setting gives ref/4 for floppy and USB instead of their expected fixed frequencies. Is that the case here, is onboard floppy unusable in slomo?
