First post, by BastlerMike
I have a QDI P4U880GRN mainboard. I'm unable to find a manual or the jumper configurations anywhere, also it is missing its bios.
Does anyone own this board and can help ?
    436.48 KiB
Reply 1 of 4, by brostenen
Found this link on a german board... Might be the one you are looking for.
http://www.dosforum.de/viewtopic.php?f=1&t=91 … start=15#p49019
Reply 2 of 4, by feipoa
Fascinating motherboard. It contains the UM8881F/UM8886F chipset from mid-1994. I have only seen the UM8881AF/UM8886AF and UM8881BF/UM8886BF chipsets.
Is the socket next to the BIOS socket for a RTC module? I don't see any battery holder on the board, nor a barrel battery.
Reply 3 of 4, by BastlerMike
I found this discussion before, but sadly nobody has a manual 😢
UM8881AF / UM8881BF does not exist, it is always UM8881F. UM8886AF / UM8881BF are the more advanced southbridge chips with integrated IDE controller.
And yes, the socket is for a RTC module
