First post, by quicknick
Hi guys, I seek help from someone that owns a Microsoft mouse (the glossy white one that yellows badly as I've seen it described around 😁 )
I have such a beast, PS/2 variety and unfortunately no PS/2-serial adapter to use it on my 486. I tried five different schematics from around the net, none worked. So I'll be eternally grateful if someone who has the original adapter can tell me the pinout by using a multimeter or led/battery combo of some sort.
Reply 1 of 12, by firage
The late 90's PS/2 stuff eventually lost serial compatibility, so make sure you have one that does do both.
The top one is marked serial and PS/2 mouse port compatible, the bottom one (probably) is PS/2 only already:
I have a couple of these guys, but no such adapter, unfortunately. Nice mice.
My big-red-switch 486
Reply 2 of 12, by Deksor
I tried one adapter on one of my microsoft PS/2 mouse but it didn't work. On the other hand I've got the exact same mouse with a serial connector (with a mousewheel ! That seems rather rare for a serial mouse !)
Reply 3 of 12, by quicknick
@firage - I have the exact one from the top picture, serial-mouse port compatible mouse 2.0
@Deksor, you can help me big time if you have a multimeter and you are willing to open up your mouse to check where each wire from this connector goes into the DB9 serial connector:
85.52 KiB
Thanks in advance!!!
Reply 4 of 12, by firage
What I can tell you is my "Serial Mouse 2.0A" is a four wire deal:
16.77 KiB
Reply 6 of 12, by firage
If the serial mouse's color code does hold up, the following should check out based on adapter stuff around the web:
-White: PS/2 pin 4 (Vcc), serial RTS (=power).
-Blue: PS/2 pin 3 (ground), serial ground.
-Orange: PS/2 pin 2 (passthrough), serial data receive.
-Yellow: PS/2 pin 6 (passthrough), serial data transmit.
-Red/black: PS/2 pin 5 (data)/pin 1 (clock), not connected for serial.
Reply 7 of 12, by quicknick
Tried today, didn't work. Also, my mouse is wired the following way:
Black - Pin 1 (data)
Yellow - Pin 3 (GND)
Orange - Pin 4 (Vcc)
Red - Pin 5 (clk)
Blue - Pin 2 (unknown/serial?)
White - Pin 6 (unknown/serial?)
Reply 8 of 12, by firage
Yeah, for some reason the colors are definitely switched around.
Try this pinout: http://s505763140.onlinehome.us/shopqvs/ds/CC2022AC_S.jpg
The serial end looks good.
Reply 9 of 12, by quicknick
That's the first one I tried. Together with your serial mouse 2.0-inspired I think I tried 6 different pinouts. Mouse works when connected to PS/2 port (on another computer, my 486 doesn't know PS/2).
Thanks for your help, but I think I'm gonna give up on this.
Reply 12 of 12, by amijim
Hello Vogoners , i have just fixed my ms mouse bought back in 1998 and i would like to ask you if you still need the schematics from the adaptor.I can do you a mapping if you nedd it ,take a look at the mouse to find out if it is the version you also have.thank you . Microsoft intelimouse serial ps2 saga.
Iwill ZmaxDP
Arima4way
Tyan s2885
Iwill MPX2
Gigabyte GA-7DPXDW+
Compaq SP700
Compaq ml350
