First post, by Lightseeker
Hi,
I'm trying to get these cheats to work with the PC version of "Bram Stoker's Dracula" (Psygnosis) which I have running in DosBox. I basically know what a hex editor is, but I can't figure out how to get those cheats to work because it doesn't even tell you which executable to use the editor on 🙁
Please, if someone is good with Hex-Editors and can explain it or even modify the file for me (I can send the *.bat file), it would be much appreciated. Here is the link to the cheat:
http://www.cheatchannel.com/files/bramstrd.htm
Reply 2 of 2, by Osprey
It's probably drac.exe that needs to be edited. I went ahead and did it for you. It's untested, though.
    drac.exe
    57.94 KiB
    27 downloads
