First post, by quicknick
So I got this board together with an AMD 5x86/133, visually everything is ok, a couple of scratches but nothing serious, no broken or shorted pcb tracks. There was a barrel battery (NiCd or NiMH) only soldered in one end, and on closer inspection I noticed it was soldered backwards (positive pin to the board's negative, and negative pin left floating). After searching the net for pictures of this board I found out that originally it was fitted with a non-rechargeable lithium battery so I soldered a CR2032 holder, checked to see if the board doesn't try to charge the battery (it doesn't), so everything looking ok I fitted the VGA, RAM, speaker and powered it. Nothing, not a single beep.
Tried with PCI and ISA video cards, different (mostly FPM) SIMMs, even without video card and/or RAM. A fellow collector was kind to help me so we tried the board with his Intel DX4 and some of his RAM, no luck.
Today I re-capped the board (all caps, even the 20-something small ones) and I even de-soldered the CMOS chip, thinking it might be damaged by the misfitted battery and somehow preventing the board from POSTing. Nothing helped.
The things that should get warm (CPU, chipset, cache chips, VRM) do get warm, VRM output is at 3.43V.
Any more ideas, or is this board history?
Thanks.
690.91 KiB
Reply 1 of 10, by feipoa
You're more likely to get responses if you include a photo of the board. People see that there is a photo, then find it worthy to read the text.
I am going through a similar situation with a motherboard right now. The symptoms are identical to yours, so far. I have started a post on eevblog and a lot of people came back with some really good troubleshooting suggestions, that are outside the norm. I highly recommend you take a look at this active post, http://www.eevblog.com/forum/repair/how-to-tr … n-oscilloscope/
Reply 2 of 10, by quicknick
Thanks, followed your advice and uploaded a photo of the board.
I've read the post on eevblog and will look there for further updates, however my lack of tools (not to mention skills and knowledge in this area) means that my chances are slim.
I don't have a 'scope or a identical board that works, and to further complicate things, the chipset is a rebrand of something else (UMC perhaps).
Can you hear a faint click in the speaker when shorting the Reset pins on your dead boards? Mine does that...
Reply 3 of 10, by feipoa
I haven't checked for that yet.
Even if it is a UMC rebrand, we don't have the UMC 8881/8886 chipsets.
One guy on eevblog was saying that this $6 poor-man's logic analyser for $6 could be of use, http://forum.hobbycomponents.com/viewtopic.php?f=102&t=1891
Reply 4 of 10, by dondiego
It's an ali finali board, the manual is here (see attachment). That board will post without a battery, you should just have removed it (by shaking it) before trying to boot. It should beep with only the cpu and the speaker, may be the jumper configuration is wrong.
    exp84491.pdf
    383.83 KiB
    127 downloads
LZDoom, ZDoom32, ZDoom LE
RUDE (Doom)
Romero's Heresy II (Heretic)
Reply 5 of 10, by quicknick
Thanks,
I never booted with the reversed battery.
I have the manual, tried almost all jumper configurations with the 5x86, now I have an AMD DX4-100 installed and the jumpers are configured correctly for it.
Reply 6 of 10, by kanecvr
The chipset is ALi. I have an identical board (also dead) and the chips read "ALi M1489".
Reply 7 of 10, by feipoa
Sorry, I meant to write "chipset datasheets", not "chipsets". Doesn't matter anyway, though, as the chipset is ALi. But, we also don't have the datasheets for that ALi chipset either.
Reply 8 of 10, by quicknick
Today's update: inspired by feipoa's thread on eevblog I proceeded to check some things. Reset line to the CPU is ok, only going high for a moment at power-up or whenever I short the "reset" header on the motherboard. Clocks also seem ok, checked ISA/PCI/CPU clock pins with one of my multimeters that should be able to measure up to 40MHz (but actually doesn't; at 33MHz it shows zero, so at first I thought I had nailed the problem. But then I lowered the clock to 25MHz and it was able to measure it accurately. I also checked the PCI frequency at 1/2 divider and found it to be ok : 25MHz with board set to 50, down to 12.5 when the board was set for 25)
Reply 9 of 10, by feipoa
Hopefully you find something. I might need to slow down on that eevblog thread a bit. I'm not getting enough sleep.
Reply 10 of 10, by rasz_pl
of course we do ;o) ALi M1489 was used as AMDs reference design for 486/586 processors
quicknick go ahead and make a thread on eevblog if you can get your hands on better equipment (friendly HAM operator, hackerspace) and have some ee knowledge already
