First post, by konc
Hi guys, does anyone know for sure/can identify the speed rating of this particular coprocessor?
548.56 KiB
I bought it labeled by the seller as 40MHz and I have no reason to question the seller's rating as it hasn't arrived yet, but how one can tell its speed anyway? I noticed that "40" (or any other speed) is not engraved on the chip like on other ULSI 387s, for example
275.51 KiB
Reply 3 of 15, by konc
Ampera wrote:
You stick it into a computer and look at the BIOS info screen.
I believe that the BIOS only displays if an FPU is present or not. Plus it'll run at the processor's speed if the motherboard doesn't have jumpers for asynchronous operation -mine doesn't, am i wrong on this?
vandenabeele andries wrote:
How can you tell? This one also has "40" engraved on the chip.
Reply 4 of 15, by BitWrangler
That just reports the speed you set it at.
Reply 5 of 15, by Ampera
Yeah, sorry I have a massive cold so my brain is half busted.
I forgot you manually set speeds for 386 stuffs.
Reply 6 of 15, by luckybob
that chip is marked 1990. that is at the tail end of the 386 era, but before AMD made theirs (iirc). So I would deduce, because it has NO other markings regarding speed, It will likely run just fine with any INTEL 386. (up to 33mhz)
Reply 7 of 15, by konc
That chip is marked end of 1993, the bottom right 4 digits are year-week. 51st week of 1993.
So yeah, based on logical assumptions an FPU manufactured almost in 1994 should be a 40MHz one.
What I'm really after is a solid way of identifying this chip from its markings, without potentially wrong assumptions.
Reply 9 of 15, by konc
sprcorreia wrote:
I sold mine recently and it was marked 40 on the righ side. It's only visible at an angle that sometimes doesn't show in photos.
I was late, second in line in that amibay thread 🤣 So I guess I'll just wait for it to arrive since even in your photo the speed isn't visible. Maybe it's there after all, just not visible as you said. Very helpful, thanks.
Reply 10 of 15, by luckybob
I saw that, but the chip was designed in 1990. (ish) so it would be designed with chips of that year in mind. At least that is how it works in my mind.
Reply 11 of 15, by Koltoroc
In this case it is probably more about the maturity of the manufacturing process. It is likely to assume that most late chips are of a high enough quality to be 40Mhz parts and binning at that point is primarily done for market segmentation instead of actual performance binning.
Reply 12 of 15, by leileilol
By that logic, Pentiums are old 1992 processors that were a year out of date in their introduction to the market. Why buy a 1992 pentium when you could buy a newer 1993 Cyrix 486-DX2 66mhz for less price at the same clock rate?
long live PCem
Reply 13 of 15, by luckybob
maybe i could word that differently. You can't design X, when X plugs into Y, until you know what Y is. I'd wager Intel told people (by 1990) 33mhz was as fast as they were going to make 386's. So it would make sense to design the chip to run at the correct speed as a 33mhz 386.
Reply 14 of 15, by konc
Checkout the second photo I posted, it's a sample selection of "same" FPUs and some of them are marked as "40"
Reply 15 of 15, by Anonymous Coward
It's made during one of the final weeks of 1993. 1993 was really the last year 386s were being sold in volume, so I would almost bet on my mother's grave it's a 40MHz part. Regardless of what the marking is, if it works at 40MHz then what difference does it make?
