Reply 20 of 51, by ruthan
- Oldbie
wrote:Anyone proved it works on some different MB than X58? I mean some Core gen 2 and newer? Maybe some bridge config tweaking would help?
There is Yamaha thread with lots of info..
Yamaha YMF7x4 Guide
On modern boards you need some DSDMA.exe TSR utility which need EMS to work, which is not working with Z97.. Could be checked by Yamaha setup utility. I tried 3 versions of Yamaha drivers and needed patched one with to make it work.
Im old goal oriented goatman, i care about facts and freedom, not about egos+prejudices. Hoarding=sickness. If you want respect, gain it by your behavior. I hate stupid SW limits, SW=virtual world, everything should be possible if you have enough raw HW.
