First post, by Smack2k
- Oldbie
Can you use a GPU Fan with two wires coming off the fan into the white femaile connector and plug it into a card that has a three pin male connector slot? The two pins will fit into the slot (black and red) but leave the third pin empty...
Hope that mekes sense...
I have a 9800 XT I receieved from a friend that works great, but the fan on it has several busted blades. I have a fan from a 9600 XT I was going to use, but it has the different pin connector as mentioned above...
