Rarest CPUs?
Reply 300 of 442, by Sphere478
TrashPanda wrote on 2022-11-12, 13:28:
It’s designed for fanless embedded systems, at a lower speed and voltage I doubt it would need much if any cooling. […]
Nemo1985 wrote on 2022-11-12, 13:23:
That's cool, can it work without heatsink in your opinion?
My k6-3+ could run at 200 mhz and v1.3, the whole system consumption was under 30 watt.
It’s worth investigating just how little cooling it requires at a range of low voltages and speeds.
Never had an embedded K6 variant before so I don’t know if AMD changed anything internally regarding power management.
In my experiments there is only one socket 5/7/ss7 cpu that could reasonably potentially be run without a heatsink and that’s a tillamook. (Under specific low volt/clock settings)
But a 2+/3+ is a close second.
I in fact have run a tillamook for some time without a heatsink.
Underclocking and undervolting help a lot
Sphere's PCB projects.
Reply 301 of 442, by TrashPanda
Sphere478 wrote on 2022-11-12, 17:49:
In my experiments there is only one socket 5/7/ss7 cpu that could reasonably potentially be run without a heatsink and that’s a […]
I'm curious how low this 2+E can go for voltage and clock speed, 350 @ 1.5v is already lower than other E series 2+ and much lower than the stock 1.9v of a Tilly, I wonder if it would be stable at 200Mhz with the voltage as low as it can go.
As for sans heatsink, while I like the idea I wouldn't run even a Tilly without the bare minimum of a heatsink even if its a shitty ally one.
Reply 302 of 442, by Sphere478
My tyan can do like 1.2? Volts? Lowest multi of a tillamook I think is 2.0
So potentially, 50x2 at 1.2 on my tyan.
Or maybe use my voltage interposer and a lab psu.
In any case, at 133 and 2.1v it’s basically cool enough to run without a heatsink
Reply 303 of 442, by ChrisK
I've an AMD-K6-III+/400ATZ 1.6V (that's 9.5W TDP compared to 7.5W TDP of the AMD-K6-2+/350AUZ) running at 6x 83MHz and 1.65V, cooled by a passive Zalman chipset heatsink. It's blown by a low rev 80mm case fan from some distance. Not even getting hand warm. Could surely be run without the fan but it's a chip that's worth a bit, so less risk = more fun.
Wouldn't run it without any heatsink, as is the case for the Tillamook.
Reply 304 of 442, by TrashPanda
ChrisK wrote on 2022-11-15, 14:31:
Yep, I wont be running it without some form of passive cooling, its a cool little CPU.
Reply 305 of 442, by Sphere478
Agree about k6-+ just a taddddd too much for no sink
But man, those tillamooks, I need to do a vid of underclocking and undervolting and running with no sink.
Reply 307 of 442, by Sphere478
It would be so cool to one day get a new cpu for socket 7. I suspect that with advances in fpga we may one day get just that.
Technically the last socket 7 cpu was a intel product though.
It was never sold, more of a science experiment. And it ran at 50mhz I believe, but it was a modified intel atom running on fpga a team at intel did this for some reason.
Reply 308 of 442, by Jasin Natael
Sphere478 wrote on 2022-11-15, 18:29:
That is cool, I didn't know that.
Reply 309 of 442, by RaiderOfLostVoodoo
I have one of these as well.
Ran it at 4x100MHz and 1.6V, so stock settings. Fan wasn't plugged in. After 5 minutes of Prime95 I shut down the system and immediately removed the heatsink. Could barely recognize any warmth.
So yeah, these can definitely be used without a heatsink. But I also wouldn't recomend it. Just remove the fan and save yourself a few watt hours.
Reply 310 of 442, by Sphere478
Can you do the test again without a heatsink?
Put some black electrical tape on the cpu and read it with a infra red thermometer
Reply 311 of 442, by debs3759
RaiderOfLostVoodoo wrote on 2022-11-15, 22:16:
I have one of these as well. Ran it at 4x100MHz and 1.6V, so stock settings. Fan wasn't plugged in. After 5 minutes of Prime95 I […]
That just means the heatsink did its job, no evidence from that that it can be run without a cooler.
Reply 312 of 442, by BitWrangler
Some of the later production P75-P100 ceramic barely need one @ 3.3V unless you wanna get 133-166 out of them of course. I think some of the split plane WinChips will just do it too.... It's all a bit "depends" on case ventilation and ambients.
Reply 313 of 442, by Sphere478
BitWrangler wrote on 2022-11-22, 01:44:
You might be right I haven’t done much work with those chips in particular
Reply 314 of 442, by Windows9566
or the Intel Overdrive chips, do those count as Rare? or the Intel 486SX 16 or 486DX 25?
R5 5600X, 32 GB RAM, RTX 3060 TI, Win11
P3 600, 256 MB RAM, nVidia Riva TNT2 M64, SB Vibra 16S, Win98
PMMX 200, 128 MB RAM, S3 Virge DX, Yamaha YMF719, Win95
486DX2 66, 32 MB RAM, Trident TGUI9440, ESS ES688F, DOS
Reply 315 of 442, by rmay635703
Windows9566 wrote on 2022-11-22, 17:55:
Sx16 are uncommon but not really rare
just a bit uncommon, not surprising considering how pointless they were.
A desktop DX2-40 is actually rarer
If you can find a 486dx-20 those are rather rare considering their pre release status,
(I can’t remember if they were ever a retail release even)
104.44 KiB
And good lord, this thing must be rare given it’s the ultimate in pointless
Reply 316 of 442, by debs3759
rmay635703 wrote on 2022-11-22, 23:50:
Sx16 are uncommon but not really rare just a bit uncommon, not surprising considering how pointless they were. A desktop DX2-40 […]
That's a retail spec - s-spec starts with S
Reply 317 of 442, by rmay635703
debs3759 wrote on 2022-11-23, 03:26:
Why were some dx2’s just labeled overdrive with only a bus speed and no “speed rating”
Reply 318 of 442, by H3nrik V!
The Overdrive "SX-20" is actually a DX2-40. First series of Overdrives were named after what they were supposed to replace, not what they were. IIRC, all 486 Overdrives are at least DX2's, which is also the case with the pictured "SX-20". https://www.cpu-world.com/sspec/SZ/SZ675.html
Reply 319 of 442, by TrashPanda
I have one of these 2.9v Pentium 90s, not sure itll even need a cooler as it barely gets warm when running.
264.04 KiB
Pentium90 2.9v
