First post, by jesolo
I've recently came into possession of an old EGA card which appears to be have been made by Nel Electronics.
I've attached a picture of the exact card that I have (only difference is the label on my BIOS chip which reads: "EGA + P + M BIOS 5.94").
376.24 KiB
EGA card
I was hoping that someone might have the jumper settings for this card.
Reply 3 of 5, by Anonymous Coward
NEL should be the same company as "Juko" if that helps.
Also, if it really does "1024" lines as stated on the BIOS chip, that would be a pretty impressive extended EGA card.
Reply 4 of 5, by keropi
I have almost the exact same card (different BIOS, you have the 74LS74 populated and your main IC must be newer as well)
it's a good and fast EGA card , settings are here (not the same layout in the picture but it's fine) http://stason.org/TULARC/pc/graphics-cards/I- … TIMATE-EGA.html
