A couple of retros I'm working on.
Reply 300 of 452, by Hamby
Vipersan wrote:
Thanks Ian .. I shall keep that in mind.. Not sure what I intend to do with them yet ..but it will be commodore related .. VIC20 […]
IanB wrote:
My Micromaster LV48 won't do them but the older ISA bus based Expro 80 appears to support them! […]
Vipersan wrote:
but the real reason I wanted to get this old programmer working was to program this chip type .. MCM 68764C, 8K EPROM, equivalen […]
MCM 68764C, 8K EPROM, equivalent to 2364 ROM
I have 6 of these chips and what makes them special is that these 2nd generation eproms are totaly pin compatible with the roms in a Commodore 64 .
In other words an 8k device in a 24 pin package ..which can be used as a straight swap for the 2364 ROM ...thus ..no adapter needed.
If you already know what you want programmed into them I can do that for you sometime.
Thanks Ian ..
VIC20 C64 or even PET ..
Maybe make a dual SID emulator ISA card for your T5200?
https://www.youtube.com/watch?v=3WCUxF43Uiw&spfreload=10
HardSID: https://en.wikipedia.org/wiki/HardSID
Reply 301 of 452, by tegrady
Vipersan wrote:
Spent the morning assembling my XT-IDE kit .. without instructions ..but most of it is straightforward .. I will need to get inf […]
I will need to get info before setting dip switches and jumpers etc..
Hopefully there will be a link on github ?
anyway ..my eyes need resting now ..
here it is assembled.
..obviously not yet tested..
Can you buy the XT-IDE pre-assembled?
Reply 303 of 452, by Vipersan
Back with the T4500C
I managed to buy a 3/4 height slim floppy from Germany ..
Yes it was a bit pricey but claimed 'new' old stock.
Chances are this one is also belt drive ..
model number EME278TB.
This one came with a grey bezzle which hopefully can be removed for fitting..
more importantly has a wide 'ZIF' which I prefer to call a MIF socket
Max insertion force ...which meant assuming I could remove the soldered flex cable from the original FDD ..without damage ..and clean it up suitably .
Could be reused for the MIF socket .
Well it did come off with a hot air station and the contacts cleaned up nicely ..
It took a while to insert this reclaimed cable into the MIF socket ..but eventually ..
Job done ..and it works.
I now have a floppy on this old laptop.
rgds
VS
    312 KiB
Reply 304 of 452, by Vipersan
Not perfect ..the FDD flap is grey not cream ..
The LCD info strip is only partially functional ..
but ..it is working and reassembled ..
Another to cross from the list
    306.82 KiB
Reply 305 of 452, by Vipersan
Not much I can do today ..
Waiting for my 486 cpu and rainbow ribbon cable to continue the 5200 mods..
So decided to take another look at the 3200sx and how it mght be used without plasma screen ..?
But ..I didn't want to remove the connections for the screen ...errr..just in case I ever found one.
Well that modem compartment underneath makes a ferfect flace to hide cables.
Lift up the hard drive..
unplug and remove the modem ribbon ..and re-route the display cables ito that empty space ..
This means the top half of the case can now be re-fitted (see pics)
The keyboard no longer fitted on account this has been repurposed for the 5200 ..but of course..
The 3200sx can be used with an external keyboard..
broke out the plastic case plug and tried an old viglen KB with an AT connector ..and the bios allows booting directly to external monitor ..
Fitted a new 3.6v lithium battery ..and powerd up ..
Nice ..it all works ..and I'm in DOS 5
I am still using the original BIOS for now ..but I will be trying a modded 3200sx bios ..later.
Which one is going to be best for me Ian ?
rgds
VS
    313.08 KiB
    313.41 KiB
    326.48 KiB
Reply 306 of 452, by Vipersan
Next question ..
Can I upgrade the memory ?
..and if so ..with what ?
I do have a few old 30 pin sticks ..but I also know from reading that the 3200sx can be mighty picky about this ..
I've attached a photo of what I have ..
Sadly not much to choose from ..
I figure these need to be fitted in pairs ..and I assume left > right is the pairing?
starting at the back near the hard drive ?
Over to you with this one possibly JZ ....
I have tried a couple at radom ..but all I ever get is parity errors at boot ..enter setup etc etc ..
    318.94 KiB
Reply 307 of 452, by Vipersan
So it would seem the T3200SX only accepts memory modules with parity ?? (unmodded)
These can be 1mb or 2mb only ?
Is there an easy way to determine what sort of modules I have ?
as I also found this posted on the net ...by a guy called SAM
I have discovered out how to make a standard 2 Meg or 1 Meg 30 pin SIMM work in the T3200sx. What you have to do is cut the trace that is connected to the CASP line (pin 28) and connect that to the CAS line (pin 2). This will result in a 1 Meg module that will work with out the parity error that you will get with out this modification. I have noticed that your 2 Meg Toshiba SIMMs have only 4 chips on them instead of the usual 9 or 3. It would be interesting to try and find the datasheet for the chips and try and figure out the pinout of a 2 Meg Toshiba SIMM. In my T3200sx my 2 Meg modules have 6 chips and I have only been able to find the datasheet for 4 of them. I think that the other 2 are the parity chips but I am not sure. I have found out that pin 19 is grounded on the 2 Meg Toshiba SIMM. I am also guessing that pin 28 on the 2 Meg Toshiba SIMM is A10 but I am not sure. By the way feel free to post this information on your website where ever you think that people will read it.
Which gets round the Parity problem..
anyone tried this ?
rgds
VS
Reply 308 of 452, by Vipersan
Some close ups of the 30 pin simms I have ..
Odd numbers of each
5 .. 3 and 1
rgds
VS
    334.38 KiB
    329.1 KiB
    323.31 KiB
Reply 309 of 452, by jaZz_KCS
You may have forgotten, Vipersan, but I did this a few pages back 😀
Basically take the last one's you photographed. They look like they could be made compatible.
Basically "what you have to do is cut the trace that is connected to the CASP line (pin 28) and connect that to the CAS line (pin 2). This will result in a 1 Meg module that will work with out the parity error that you will get with out this modification"
I did this as you can see in my pictures (although it's very hard to see the tiny trace cut I made, you have to zoom in)
Reply 312 of 452, by Vipersan
jaZz_KCS wrote:
You may have forgotten, Vipersan, but I did this a few pages back :) […]
Done so many mods and fixes lately ..I get confused ..🤣
and add to that the senior moments.
cheers buddy.
Reply 313 of 452, by Vipersan
just found your mod photos JZ ..and I then looked at one of my 9 chip 'bricks' ..🤣
Curiously I dont think I will need to cut the trace to pin 28 ..as it looks un-linked ??
pin 28 goes to a link pad which can be solder linked ???
see the poor close up.
There is also another link/bridge solder pad on pin 29 .. linked to pin 26.... DP/QP
no idea what it is for ..(also unlinked)
Perhaps the same memory simm is sold as parity or non parity ..depending on one or both of those links ?
If I read this right the unattached pin 28 would indicate these are already NON parity ???
rgds
VS
Just found this ..which might shed some light...
https://allpinouts.org/pinouts/connectors/mem … am-simm-30-pin/
Problem is ..these may be 4mb simms ..so not acceptable to the 3200 ?
    269.97 KiB
Reply 314 of 452, by Vipersan
So popped a blob of solder on 2 simms linking the pads discussed above this effectively links pin2 to pin 28 ..
popped in the 2 simms and the 3200 booted straight into DOS 5 without complaint ..
No idea if these simms are active..
certainly no change in the extended memory checked at boot
still showing 384K
..but at least there are no parity errors flagged up ..
Now what ?
Reply 315 of 452, by Vipersan
Tried to catch the vga bios info for you Ian ..but either I'm too slow or not rebooting in a way that shows it ?
rgds
VS
btw ..
which bios is the most recently modded for the 3200sx (most versatile that will accept any Hard drive ?)
    319.91 KiB
Reply 316 of 452, by IanB
If you have connected pad 2 to pad 28, that's not what the mod requires and may have messed up the signals stopping the SIMMs from being detected altogether, although it looks like that solder link is designed as part of this mod. I think there should be another link that must be broken as well to isolate pad 28.
Before the mod you will have pad 2 connected to some chips and pad 28 connected to others, after the mod pad 2 should still be connected to it's original chips and also to the chips that originally went to pad 28. Pad 28 itself should be completely isolated with no continuity to anything. The pin 26/29 mod is for SIMM slots that don't have separate data in and data out for the parity bit and the link connects them together. I don't know if the T3200SX requires this.
Vipersan wrote:
btw ..
this one here (beta3):
Toshiba T5200 mods and upgrades
Reply 317 of 452, by Vipersan
Hi Ian ..
flashed one of my 1024 chips (yes they did finally arrive from China)
with T3200SX Award 89 BIOS patch Beta0-3
..and yes it does boot just fine ..but does not run the 40mb Conor ..(DOS 5)
Hence missing operating system ..
I guess the new bios just doesn't like the geometry of these ancient legacy drives ..
rgds
VS
    322.27 KiB
Reply 318 of 452, by Vipersan
I've tried to represent what I believe to be the layout of the 9 chip simm with the solder bridge pads ..
normally open between 2 and 28
rgds
VS
    102.27 KiB
Reply 319 of 452, by IanB
This appears to be the same problem you had with the T5200. I have a 64MB compact flash and looked into this a bit more.
This has a native drive shape of 490 cylinders, 8 heads and 32 sectors per track as read directly from the CF but when the shape is read via the BIOS (in this case XTIDE) it comes back as 124 cylinders, 16 heads and 63 sectors per track. This amounts to about the same capacity (125440 sectors vs 124992 sectors) so will still give about the same storage but with a different geometry so my initial suspicion when we discussed this previously was correct. Those very small drives usually have 17 sectors per track so the geometry will definitely be translated to 63 sectors per track when connected via XTIDE.
I don't know if this behaviour with small drives is standard with all translating BIOSes or just a feature of XTIDE but reformatting and reinstalling should make it work again.
